Which firmware: 4.1.1.13 or 4.1.3.1
  • 1.  Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Jul 12, 2016 03:54 AM
    Hi we are curious which one to use for our customers:
    - 6.4.2.6-4.1.1.13
    - 6.4.2.6-4.1.3.1
    Our customers use Client Match, Network printing, Cloud services, Google Cast and Apple TV.
    Which one is better, or which one to choose? I don't understand both releases...
    ps we use AMP 8.2.1
    Thanks in advance.
  • 2.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Jul 13, 2016 10:16 PM
    4.1.3.1 fixes a security vulnerability and should be used.
  • 3.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Jul 14, 2016 03:15 AM
  • 4.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Aug 09, 2016 05:55 AM
    the automatic firmware check on our Virtual Controller (2 IAP 205's) says 4.1.3.0 is the latest. How come? It should be 4.1.3.1, right?
    PS: also, how do I check if both controllers updated their firmware, and not just 1? Through the web-interface of the virtual controller it doesn't seem to show which firmware an IAP has. It only shows which firmware the VC has.
  • 5.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Aug 09, 2016 07:11 AM
    In theory, it should be the latest software here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/22084/Default.aspx
    I will check and see why that is not the case.
    An AP should not be able to join a cluster if the firmware is not the same as the VC.
  • 6.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Aug 10, 2016 02:05 AM
    That would suggest to use 4.1.1.13 instead of 4.1.3.1 (or 4.1.3.0 even).
    Thanks for checking. Curious about the outcome.
  • 7.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Aug 23, 2016 06:29 AM
    It's still saying 4.1.1.13. Not 4.1.3.0, not 4.1.3.1, not 4.1.3.2. So... should we use 4.1.1.13 ? Or 4.1.3.2?
  • 8.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Aug 31, 2016 09:35 AM
    hello?
  • 9.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Aug 31, 2016 09:38 AM
    What features do you need?  It might not matter?
  • 10.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Aug 31, 2016 09:41 AM
    I don't know if it matters. That's why I'm asking :-) What do you advise? Most important thing is that all security updates are applied of course.
  • 11.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Aug 31, 2016 09:42 AM
    4.1.3.1 would have all the security updates.  That is the answer to your question.
  • 12.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Aug 31, 2016 09:52 AM
    thanks. But the 205 is still at 4.1.3.0 and says there's no new version available.
  • 13.  RE: Which firmware: 4.1.1.13 or 4.1.3.1
    Posted Aug 31, 2016 10:20 AM
    4.1.3.0 has all the security updates in that train.  4.1.3.1 has no security updates in the release notes.  We need to check on why it is not available in "Check updates".
