Hello,I need to upgrade the following controllers to 6.4.4.16:Aruba3600Aruba6000Aruba3200Aruba3400Aruba650and I have the following firmware files:ArubaOS_6xx_6.4.4.16_61809ArubaOS_70xx_6.4.4.16_61809ArubaOS_72xx_6.4.4.16_61809ArubaOS_MMC_6.4.4.16_61809Could anybody tell me how to understand which firmware can be used with the listed platforms?Thanks in advance!
If you downloaded it from the support site, it tells you in the folder what platform each download is assigned to:
Thanks to all for your reply.
What about 6000?
ArubaOS_MMC_6.4.4.16_61809 because there is a M3 card in.
except there is a SCI or SCII Card inserted. That was way past in the begining and is not supported by 6.x. I guess last support was 5.0.x
Best would be to upgrade the Environment to newer products with new featuresets.
ArubaOS_6xx_6.4.4.16_61809 -> for all 600 Series Controllers, so also for the 650
ArubaOS_70xx_6.4.4.16_61809 -> for all 70xx Series Controllers
http://www.arubanetworks.com/me/products/networking/controllers/ - Branch/Standalone Controller
ArubaOS_72xx_6.4.4.16_61809 -> for all 70xx Series Controllers
http://www.arubanetworks.com/me/products/networking/controllers/ - Campus Hardware Controller
ArubaOS_MMC_6.4.4.16_61809 -for all 3000 Series and M3
End of Support will be 01-Aug-21
Source:
http://www.arubanetworks.com/me/support-services/end-of-life/#MobilityControllers
