which is the threshold of Spectrum load balancing?
  • 1.  which is the threshold of Spectrum load balancing?
    Posted Jul 29, 2014 03:34 AM
    I would like to test spectrum load balancing in IAP.  I can only choose mode of SLB (Radio, channel, radio+channel), but I would like to know when AP change one of this mode. I found the AP send error code 17 when it wants to refuse client. Error code 17 indicates that the AP is too busy to accept more associations. How many clients are there in the busy AP? How can i configure it?
    Thanks for all,
  • 2.  RE: which is the threshold of Spectrum load balancing?
    Posted Jul 29, 2014 07:57 AM
    Your best bet is to use client match instead of SLB to be honest. Upgrade your IAP to 4.0+ and turn it on.
    Client Match will work, in my opinion, better than SLB.
