This is something that you should best discuss with your Aruba Partner. They can advise the best products for your situation.
If the 10x AP335 now provide the performance that you would expect, you may find an equivalent AP5xx or AP6xx for that. But you did not mention if you are looking for additional scale, speed, coverage, features, spectrum, etc. It's just easier to speak with your Aruba partner and get their advice for an optimal solution within your requirements and budget.
Original Message:
Sent: Jul 04, 2024 06:42 PM
Subject: Which Product is correct for me
I need to add 10 APS to a Meeting Facility Each Room will handle about 200 guests MAX. SO i would need at least 1000 IP's available.
We are currently using 10 AP 335 units. I would like to know should i be using a 500 series or a 600 series unit to replace these.
Any help would be great I need to upgrade this system ASAP
