Which recommanded version for WLC 7205
  • 1.  Which recommanded version for WLC 7205
    Posted Feb 07, 2017 05:09 AM
    I am trying to figure out which version is the best recommanded for a WLC 7205. I currently have the 6.5.0.3
    would it be a good idea to upgrade to 6.5.1.2 or 8.0.1.0 ?
    Thank you,
    AL
  • 2.  RE: Which recommanded version for WLC 7205
    Posted Feb 07, 2017 05:18 AM
    I guess it depends on what you are configuring. ArubaOS 8.0.1.0 and ArubaOS 6.5.1.2 are still early deployment versions.
    I would suggest to stick with the latest general deployment, when configuring a (bigger) production environment. In that case it would be ArubaOS 6.5.0.3.
    If it is a smaller environment or a pilot / proof of concept environment or an environment with a very basic configuration, I would suggest to test ArubaOS 8.0.1.0.
  • 3.  RE: Which recommanded version for WLC 7205
    Posted Feb 07, 2017 05:28 AM
    Well it's for a production environment, I guess we will keep the 6.5.0.3 in the moment.
    Thank you for your fast answer.
    AL
