While deactivated, preemption is still working after failover
  • 1.  While deactivated, preemption is still working after failover
    Posted Jan 16, 2014 03:32 AM
    Hi guys,
    I got two 7220 controllers in an Active-Master (Preferred) / Backup-Master (Backup) VRRP redundancy configuration. Pre-emption is NOT checked in the VRRP addresses. Preferred Master has a priority of 110, Backup Master has a priority of 100. When testing failover, the APs failed from Preferred Master to Backup Master perfectly. However, when Preferred Master came back online, the APs went back to Preferred Master. Again, Pre-emption is NOT checked and I cannot figure out why the APs went back to Preferred Master.
    Controllers are running 6.2.1.5 code
    I do not want the APs to go back to Preferred Master in a failover scenario. Any ideas why this might be happening?
    Here the vrrp configuration :
    PREFERRED-MASTER
    master-redundancy
    master-vrrp 101
    peer-ip-address 192.168.1.10 ipsec 77db8ba3817b029922e150f79fcbbeeb8d68ca677bb30755
    vrrp 101
    priority 110
    authentication PASSWORD
    ip address 192.168.1.12
    vlan 1
    tracking master-up-time 30 add 20
    no shutdown
    BACKUP-MASTERr:
     master-redundancy
    master-vrrp 101
    peer-ip-address 192.168.1.11 ipsec 0464b861ed6ff4f3cc1c00dafa967be7f4bba843c12c78a7
    vrrp 101
    description "Backup-Master"
    vlan 1
    no shutdown
    Thanks!
    #7220
  • 2.  RE: While deactivated, preemption is still working after failover
    Posted Jan 16, 2014 03:38 AM
    Additionnaly, number of license are different on the controllers:
    Preferred Master : 100 licenses AP and PEF
    Backup Master : 64 licenses AP and PEF
  • 3.  RE: While deactivated, preemption is still working after failover
    Posted Jan 16, 2014 04:03 AM
    Your config looks good.
    I guess you've also already checked the "show vrrp" outputs on both before/after tests for anomalies?
    Final suggestion is a cold boot of both controllers if not already done?
    From there, probably best to log with TAC?
  • 4.  RE: While deactivated, preemption is still working after failover
    Posted Jan 16, 2014 04:26 AM
    Thanks you The.racking.monkey for your answer,
    Here is the results of the show vrrp command after the reboots of the preferred master
    PREFERRED-MASTER
    Virtual Router 101:
    Description Preferred-Master
    Admin State UP, VR State MASTER
    IP Address 192.168.1.12, MAC Address 00:00:5e:00:01:65, vlan 1
    Priority 110, Advertisement 1 sec, Preemption Disable Delay 0
    Auth type PASSWORD, Auth data: ********
    tracking type is master-up-time, duration 30 minutes, value 20
    tracked priority 110
    BACKUP-MASTER
    Virtual Router 101:
    Description Backup-Master
    Admin State UP, VR State BACKUP
    Priority 100, Advertisement 1 sec, Preemption Disable Delay 0
    tracked priority 100
    I will try a cold boot of both controllers later in peak hours.
  • 5.  RE: While deactivated, preemption is still working after failover
    Posted Jan 16, 2014 04:39 AM
    Also helpful:
    show vrrp <vrid> statistics
    show log system 50 | include vrrp
    Would be helpful to see the transtition.
  • 6.  RE: While deactivated, preemption is still working after failover
    Posted Jan 16, 2014 04:55 AM
    Set same priority to both of the controllers - any try.
  • 7.  RE: While deactivated, preemption is still working after failover
    Posted Jan 16, 2014 05:17 AM
    indeed, need more coffee.
  • 8.  RE: While deactivated, preemption is still working after failover
    Posted Jan 16, 2014 05:27 AM
  • 9.  RE: While deactivated, preemption is still working after failover
    Posted Jan 16, 2014 05:29 AM
    Thanks you kdisc98 and sadams for your answers.
    Fix the same priority for both controller sounds good for me. I see this in the Aruba User Guide
    If VRRP preemption is disabled (the default setting) and all controllers share the same
    priority, the first controller that comes up becomes the master.
    I will try this and let you know if it has worked.
    Thanks you
  • 10.  RE: While deactivated, preemption is still working after failover
    Posted Jan 16, 2014 05:30 AM
    waiting to hear that it worked fine for u.
    We are here to help :)
  • 11.  RE: While deactivated, preemption is still working after failover
    Posted Feb 21, 2014 06:08 AM
    Thanks you guys , it worked when the priority are the same. :smileyhappy:
  • 12.  RE: While deactivated, preemption is still working after failover
    Posted Feb 21, 2014 06:13 AM
    Thanks for the update. Glad it worked for u.
    K+ and mark as solution
  • 13.  RE: While deactivated, preemption is still working after failover
    Posted Jul 20, 2015 08:56 AM
    Sorry to reply to an old thread but I'm having the same problem.
    VRRP piority110/100. Pre-emption off. priority will switch back to primary 7010 controller after rebooting it. Setting same priority (100), the backup controller will always be active (it has a higher management IP address).
    There's no difference between enabling or disabling preemtpion.
