Network Management
While we contain a Rogue AP on the Airwave same is not contained in the Cisco Controller
  • 1.  While we contain a Rogue AP on the Airwave same is not contained in the Cisco Controller
    Posted Feb 14, 2016 04:37 AM
    While we contain a Rogue AP on the Airwave it also gets Manually Contained on the Aruba Controller but in case a Rogue is learnt through a Cisco Controller and same is reflected on the Airwave. But if we contain it in Airwave it does not auto contain on the Cisco Controllers, we have to manually contain on the Cisco Device by logging to it separately. Does it require any additional settings on the AIRWAVE to push containment to Cisco Controllers.
  • 2.  RE: While we contain a Rogue AP on the Airwave same is not contained in the Cisco Controller
    Posted Feb 14, 2016 09:56 AM
  • 3.  RE: While we contain a Rogue AP on the Airwave same is not contained in the Cisco Controller
    Posted Feb 14, 2016 10:50 AM
    Thanks for your reply Colin.
    Both containment options are already set as YES but the containment on AIRWAVE does not push to the cisco controllers. I waited for about 15 mins to check if it takes time but it does not work out. Maximum no. of APs to contain a Rogue is set to default 3.
