Who authenticate the MAC addresses, if I use external RADIUS for 802.1x?
  • 1.  Who authenticate the MAC addresses, if I use external RADIUS for 802.1x?
    Posted Nov 08, 2016 08:41 AM
    I find there is a possibility to configure WPA2-Ent with external RADIUS by MAC and 802.1x authentication at the same time, but who does the MAC authentication, the external RADIUS server or the IAP?
    I asked this because if I define a WPA2-PSK, and I checked the MAC authentication option, then new menu items show up, and I can define an Internal Server, and I can configure MAC addresses on this server. But if I use external radius for 802.1x, and I checked the MAC authentication checkbox, no new menu items show up.
    Should I configure the filtered MAC addresses on the RADIUS server, am I rigth?
    Thanks!
  • 2.  RE: Who authenticate the MAC addresses, if I use external RADIUS for 802.1x?
    Posted Nov 08, 2016 08:52 AM
    You would use a policy engine like ClearPass to use MAC address during the authorization phase.
  • 3.  RE: Who authenticate the MAC addresses, if I use external RADIUS for 802.1x?
    Posted Nov 08, 2016 09:14 AM
    Thanks!
    If you use an external server for WPA2-Enterprise (radius), you also MUST use the same external server for mac authentication.  If you use PSK encryption, you can use the internal server.
  • 4.  RE: Who authenticate the MAC addresses, if I use external RADIUS for 802.1x?
    Posted Nov 08, 2016 09:20 AM
    Now it's clear for me, thanks!
