Why can't I ping my Aruba S1500-48p from a particular host.
  • 1.  Why can't I ping my Aruba S1500-48p from a particular host.
    Posted Aug 10, 2015 04:09 PM
    We've just set up our first stack of S1500-48ps, and are having some difficulty. This stack replaced a work stack, and was uplinked into an existing network that's been chugging away for a decade or so.
    At first, we couldn't get the voip-profile to work consistently with our Avaya IP phones. Configuring a set of ports to trunk mode made those work - though I don't know why they didn't work in the first place.
    Then our network printers were failing to get DHCP assigned IPs.
    I can see the requests in the server's logs - but when I ping the management IP on the S1500, I get no reply. Other switches, other machines are able to ping the management IP - though not from the same switch. Other clients on the stack can get DHCP assigned addresses without issue.
    To make matters stranger, if I ping from the switch to the server - it can then ping the switch for a short time. It's almost as if some sort of arp filtering is happening, but I can't figure out why.
    I have disabled mstp completely on the switch, tried moving the printers to trunk ports, verified that their MACs are being learned all the way to the server...
    Seems like there's some failure to broadcast somewhere along the line. I've tried disabling all the storm-control options I could find, but that didn't have a visible effect.
    Edit: I still have no idea what's going on with pinging the S1500, or DHCP failures, but putting in a static IP address on the printers didn't work until I also put in a default gateway. Which is ludicrous!
    I feel like there's a critical piece here, but not sure what it is.
    Further edit:
    I disabled stp on the Extreme switch this stack is uplinked to, and the printers started working perfectly.
    Now the IP phones refuse to get an IP address, though... What a mess.
  • 2.  RE: Why can't I ping my Aruba S1500-48p from a particular host.
    Posted Aug 10, 2015 04:44 PM
    Can you please post your switch config?
  • 3.  RE: Why can't I ping my Aruba S1500-48p from a particular host.
    Posted Aug 11, 2015 10:10 AM
    Because I have been flailing around trying to fix this, it's a mess, but here is the current config:
    # Configuration file for ArubaOS
    version 7.4
    enable secret XXX
    hostname "mhsidf2-1"
    clock timezone MDT -6
    location "Building1.floor1"
    controller config 33
    ip access-list eth validuserethacl
    permit any
    netservice svc-dhcp udp 67 68
    netservice svc-dns udp 53
    netservice svc-ftp tcp 21
    netservice svc-h323-tcp tcp 1720
    netservice svc-h323-udp udp 1718 1719
    netservice svc-http tcp 80
    netservice svc-https tcp 443
    netservice svc-icmp 1
    netservice svc-kerberos udp 88
    netservice svc-natt udp 4500
    netservice svc-ntp udp 123
    netservice svc-sip-tcp tcp 5060
    netservice svc-sip-udp udp 5060
    netservice svc-sips tcp 5061
    netservice svc-smtp tcp 25
    netservice svc-ssh tcp 22
    netservice svc-telnet tcp 23
    netservice svc-tftp udp 69
    netservice svc-vocera udp 5002
    ip access-list stateless allowall-stateless
    any any any permit
    ip access-list session cplogout
    user alias controller svc-https dst-nat 8081
    ip access-list stateless cplogout-stateless
    user alias controller sys-svc-https dst-nat 8081
    ip access-list stateless dhcp-acl-stateless
    any any svc-dhcp permit
    ip access-list stateless dns-acl-stateless
    any any svc-dns permit
    ip access-list stateless http-acl-stateless
    any any svc-http permit
    ip access-list stateless https-acl-stateless
    any any svc-https permit
    ip access-list stateless icmp-acl-stateless
    any any svc-icmp permit
    ip access-list stateless logon-control-stateless
    any any svc-natt permit
    ip access-list session validuser
    network 169.254.0.0 255.255.0.0 any any deny
    any any any permit
    user-role authenticated
    user-role denyall
    user-role denydhcp
    user-role guest
    user-role logon
    user-role preauth
    crypto ipsec transform-set default-boc-bm-transform esp-3des esp-sha-hmac
    crypto ipsec transform-set default-rap-transform esp-aes256 esp-sha-hmac
    mgmt-user admin root XXX
    ntp server 172.16.1.18
    firewall disable-stateful-h323-processing
    ip domain lookup
    aaa authentication mac "default"
    aaa authentication dot1x "default"
    aaa server-group "default"
    auth-server Internal
    set role condition role value-of
    aaa profile "default"
    aaa authentication captive-portal "default"
    aaa authentication vpn "default"
    aaa authentication mgmt
    aaa authentication wired
    web-server
    aaa password-policy mgmt
    traceoptions
    probe-profile "default"
    protocol icmp
    qos-profile "default"
    policer-profile "default"
    ip-profile
    default-gateway 172.16.16.1
    mode-button
    interface-profile ospf-profile "default"
    area 172.16.16.6
    interface-profile pim-profile "default"
    interface-profile igmp-profile "default"
    stack-profile
    ipv6-profile
    activate-service-firmware
    aruba-central
    rogue-ap-containment
    interface-profile switching-profile "default"
    interface-profile switching-profile "phone"
    switchport-mode trunk
    trunk allowed vlan 3
    interface-profile switching-profile "uplink"
    no storm-control-broadcast
    no storm-control-unknown-unicast
    interface-profile voip-profile "voice"
    voip-vlan 3
    voip-mode auto-discover
    interface-profile tunneled-node-profile "default"
    interface-profile poe-profile "default"
    interface-profile poe-profile "poe-factory-initial"
    enable
    interface-profile enet-link-profile "autooff"
    speed 100
    duplex full
    no autonegotiation
    interface-profile enet-link-profile "default"
    interface-profile lldp-profile "default"
    lldp transmit
    lldp receive
    no lldp med-tlv-select network-policy
    med enable
    proprietary-neighbor-discovery
    interface-profile lldp-profile "lldp-factory-initial"
    lldp transmit
    lldp receive
    med enable
    interface-profile gvrp-profile "gvrp-on"
    enable
    interface-profile gvrp-profile "iaps"
    interface-profile mstp-profile "default"
    interface-profile mstp-profile "edge"
    portfast
    interface-profile pvst-port-profile "default"
    interface-profile port-security-profile "default"
    loop-protect auto-recovery-time 60
    vlan-profile dhcp-snooping-profile "default"
    vlan-profile mld-snooping-profile "default"
    vlan-profile igmp-snooping-profile "default"
    vlan-profile igmp-snooping-profile "igmp-snooping-factory-initial"
    snooping
    spanning-tree
    gvrp
    mstp
    lacp
    vlan "1"
    vlan "3"
    description "VoiceVlan"
    vlan "6"
    description "CaptivePortal"
    interface gigabitethernet "0/0/0"
    interface gigabitethernet "0/0/1"
    interface gigabitethernet "0/0/2"
    interface gigabitethernet "0/0/3"
    interface gigabitethernet "0/0/4"
    interface gigabitethernet "0/0/5"
    interface gigabitethernet "0/0/6"
    interface gigabitethernet "0/0/7"
    interface gigabitethernet "0/0/8"
    interface gigabitethernet "0/0/9"
    interface gigabitethernet "0/0/10"
    interface gigabitethernet "0/0/11"
    interface gigabitethernet "0/0/12"
    interface gigabitethernet "0/0/13"
    interface gigabitethernet "0/0/14"
    interface gigabitethernet "0/0/15"
    interface gigabitethernet "0/0/16"
    interface gigabitethernet "0/0/17"
    interface gigabitethernet "0/0/18"
    interface gigabitethernet "0/0/19"
    interface gigabitethernet "0/0/20"
    interface gigabitethernet "0/0/21"
    interface gigabitethernet "0/0/22"
    interface gigabitethernet "0/0/23"
    interface gigabitethernet "0/1/0"
    interface gigabitethernet "0/1/1"
    interface gigabitethernet "1/0/0"
    interface gigabitethernet "1/0/15"
    interface gigabitethernet "1/0/46"
    interface gigabitethernet "1/0/47"
    interface gigabitethernet "2/0/1"
    interface gigabitethernet "2/0/2"
    interface vlan "1"
    ip directed-broadcast
    ip address 172.16.16.6 255.255.240.0
    device-group ap
    interface-group gigabitethernet "default"
    apply-to ALL
    interface-group gigabitethernet "phones"
    apply-to 1/0/46
    interface-group gigabitethernet "ports"
    apply-to 0/0/0-0/0/43,1/0/0-1/0/41,2/0/0-2/0/43
    qos trust auto
    interface-group gigabitethernet "uplink"
    apply-to 0/0/44-0/0/47,1/0/42-1/0/45,1/0/47,2/0/44-2/0/47
    interface-group gigabitethernet "uplinks"
    apply-to 0/1/0-0/1/1,1/1/0-1/1/1,2/1/0-2/1/1
    qos trust auto
    syslocation "XXX Front Offie"
    syscontact "netadmin@mesd.us"
    snmp-server community Zer0t0uchpr0visi0ning view ALL
    snmp-server community public view ALL
    snmp-server view ALL oid-tree iso included
    snmp-server group public v1 read ALL
    snmp-server group public v2c read ALL
    snmp-server group ALLPRIV v1 read ALL notify ALL
    snmp-server group ALLPRIV v2c read ALL notify ALL
    snmp-server group ALLPRIV v3 noauth read ALL notify ALL
    snmp-server group AUTHPRIV v3 priv read ALL notify ALL
    snmp-server group AUTHNOPRIV v3 auth read ALL notify ALL
    snmp-server group Zer0t0uchpr0visi0ning v1 read ALL
    snmp-server group Zer0t0uchpr0visi0ning v2c read ALL
    snmp-server enable trap
    process monitor log
    end
  • 4.  RE: Why can't I ping my Aruba S1500-48p from a particular host.
    Posted Aug 11, 2015 02:18 PM
    So I resorted to a "write erase all".  This is the new current config.
    version 7.4
    enable secret "dxxx"
    clock timezone PST -8
    controller config 6
    permit any
    any any any permit
    any any any permit
    user-role denyall
    user-role denydhcp
    user-role guest
    user-role logon
    user-role preauth
    mgmt-user admin root eccc
    mgmt-user switchroot root ccc
    ip domain lookup
    web-server
    traceoptions
    protocol icmp
    ip-profile
    mode-button
    enable factory-default
    area 0.0.0.0
    stack-profile
    ipv6-profile
    aruba-central
    voip-vlan 3
    voip-dscp 8
    voip-dot1p 7
    enable
    lldp transmit
    lldp receive
    med enable
    snooping
    snooping
    spanning-tree
    gvrp
    mstp
    lacp
    vlan "1"
    vlan "3"
    vlan "6"
    interface vlan "1"
    description "Default"
    interface vlan "3"
    ip address dhcp-client
    device-group ap
    interface-group gigabitethernet "aps"
    apply-to 0/0/44-0/0/47,1/0/42-1/0/47,2/0/44-2/0/47
    apply-to ALL
    apply-to 0/1/0
    process monitor log
    end
    The voip-profile still refuses to work for IP phones, so I had to add the phones to the "aps" interface group (to get them to actual function on VLAN 3).
    Even after that, the IP phones come up with "Finding router..." forever, unless I give each phone a static ip address - implying that they cannot reach the router for some reason.
    All in all, this has been the worst possible scenario for this equipment. Hoping to find out what's going wrong before I try deploying the other 80 switches. :)
  • 5.  RE: Why can't I ping my Aruba S1500-48p from a particular host.
    Posted Aug 11, 2015 02:39 PM
    Before you wiped the config, did you verify your VoIP phones are ending up in VLAN 3?  You can use 'show mac-address-table' to confirm. I believe with the Avaya phones you'll need to use static voip mode as they probably use LLDP rather than CDP.  If so, try the following:
      voip-mode static
    Since you wiped out the switch, you'll need to recreate your 'phones' interface group and apply the voip profile there.
    Also, can you please provide the interface configuration of your upstream switch?  Would like to know how the uplink port is configured on that switch.
  • 6.  RE: Why can't I ping my Aruba S1500-48p from a particular host.
    Posted Aug 12, 2015 11:20 AM
    Yes, I can verify that phones are, according to the switch, being made a member of the tagged vlan 3.
    It's strange because I already have, at other locations, S1500s using auto-discover on LLDP capable IP phones.
  • 7.  RE: Why can't I ping my Aruba S1500-48p from a particular host.
    Posted Aug 12, 2015 11:53 AM
    Setting the voip mode to static causes the IP phone to never be made a member of the tagged vlan specified in the voip profile.
  • 8.  RE: Why can't I ping my Aruba S1500-48p from a particular host.
    Posted Aug 10, 2015 10:49 PM
    Did you change spanning tree modes and are now running PVST, or is STP turned off?
    What network device is the S1500 trunked to?  Is that device using PVST, RSTP, MSTP?
    What VLANs are the clients, printers, etc?  What's the mgmt VLAN?
    As Tim suggested, a config would be helpful.
  • 9.  RE: Why can't I ping my Aruba S1500-48p from a particular host.
    Posted Aug 11, 2015 07:38 AM
    I'll post the config when I get to the office this morning, but some easy information to provide:
    Relevant ports are on Vlan 1 as their native.  Management Vlan is 1.
    My original post does specifiy "I have disabled mstp completely on the switch" in addition to other attempts to solve the problem.
    I believe the fix will be with the uplinked switch, though, which is an Extreme SummitX series stack. Making any change to stp on that stack seems to allow things to work normally on the Aruba stack for a brief moment and then (I assume once the topology changes complete on the Extreme stack) they go back to not working.
    The weird thing, the stack of cheap Neatgear devices that these S1500s are replacing worked just fine. It's a head scratcher, and more than a little worrying.
    Well, as I said, I'll post the S1500 configs from the office.
