  Thread closed by the administrator, not accepting new replies.
  • 1.  Why Clearpass only supports thick provisioned disks
    Posted Feb 28, 2024 11:10 PM
    No replies, thread closed.
    Hi
    were in the midst of upgrading our clearpass server, it seems the requirement for the disk is Thick Provisioning, is this still compulsary? If anyone  knows the logic behind why the disk type needs to be Thick instead of thin, would appreciate and feedback.
    I can understand it if the underlying storage has limited space but what if the underlying storage has more than enough free space? cant we set the disk type to thin provisioning in that case?
    TIA
  • 2.  RE: Why Clearpass only supports thick provisioned disks
    Posted Feb 29, 2024 09:57 AM
    My understand is so it's never oversubscribed.  A Network Access Control system is a critical piece of hardware/software and I wouldn't want to go down because of oversubscribed storage.
  • 3.  RE: Why Clearpass only supports thick provisioned disks
    Posted Feb 29, 2024 10:39 AM
    I always thought the requirements are based on what the physical appliances have, hence the high storage and CPUs. The think provisioning is probably due to the appliances having spindle disks instead of SSDs.
    With regards to VMs, I would check with what options the storage has. Many have their own method of deduplication and thin provisioning, letting you create VMs with thick disks.
    My .02..
  • 4.  RE: Why Clearpass only supports thick provisioned disks
    Posted Mar 01, 2024 07:54 AM
    This is a duplicate post; more answers here.
