Why does not the Antenna Parameters option value exist when I set it to GUI in 6.5.4.2?
  • 1.  Why does not the Antenna Parameters option value exist when I set it to GUI in 6.5.4.2?
    Posted May 10, 2018 12:12 AM
    I use the controller 7205, and the OS version uses 6.5.4.2.
    I am using the AP314 and I want to manually input the gain value of the external antenna
    Like the image, there is no gain item on the GUI screen.
    Does anyone have similar problems?
  • 2.  RE: Why does not the Antenna Parameters option value exist when I set it to GUI in 6.5.4.2?
    Posted May 10, 2018 07:19 AM
    Try clearing your browser cache to see if it fixes it.
  • 3.  RE: Why does not the Antenna Parameters option value exist when I set it to GUI in 6.5.4.2?
    Posted May 17, 2018 03:41 AM
     Thanks for your reply.
    I changed the operating system and the related symptoms disappeared.
