Why does the IAP-275 have 1 large and 2 small antennas for the 5GHz, but 3 large antennas for 2.4GHz
  • 1.  Why does the IAP-275 have 1 large and 2 small antennas for the 5GHz, but 3 large antennas for 2.4GHz
    Posted Dec 28, 2016 08:27 AM
    I opened up an IAP-275 to look at mounting options on a portable site survey kit and noticed that of the 6 antennas, 2 are shorter. These 2 short antennas are both 5GHz antennas (5G1 and 5G2). The 2.4GHz antennas are all large ones. Is there a reason or what's the difference between these antennas?
  • 2.  RE: Why does the IAP-275 have 1 large and 2 small antennas for the 5GHz, but 3 large antennas for 2.4GHz
    Posted Jan 02, 2017 11:18 AM
    There are two V-pol and one H-pol antenna per radio (3 antennas per radio). The H-pols require a different design than the V-pols, so they are different sizes.
  • 3.  RE: Why does the IAP-275 have 1 large and 2 small antennas for the 5GHz, but 3 large antennas for 2.4GHz
    Posted Jan 03, 2017 03:08 AM
    Hi jhoward,
    How come is there a difference between the 2.4GHz and 5GHz? So the 2.4GHz has different antennas?
    Tom
  • 4.  RE: Why does the IAP-275 have 1 large and 2 small antennas for the 5GHz, but 3 large antennas for 2.4GHz
    Posted Jan 03, 2017 09:18 AM
    Different frequencies means different length of antennas to maintain the same gain (which is why you will often see dual-band omnis that have different gains depending on 2.4Ghz or 5Ghz). And yes, each radio has three antennas, 2 V-pol and 1 H-pol antenna (v-pol is vertically polarized, h-pol is horizontally polarized).
