you should note that VSX is not a stacking feature like VSF.
VSX is designed to provide HA for deployment of multi-chassis link redundancy while maintaining separate control planes.
This is in contrast to VSF, which is designed to simplify deployment of multiple physical devices by offering a single point of configuration and mgmt that uses shared control plane across the entire stack.
each of them have their own advantages.
VSX's ability to have two control plane while using "sync" for configuration of the switches to be the same, is a big plus point. This means that you can upgrade without impacting having to take both switches down, thats why VSX supports live upgrade in which you can upgrade the pair of VSX switches without any down time (Assuming all the other switches/servers are dual connected). This is not possible in a solution where you have one control plane between multiple switches. Then you have a number of related features like Active gateway (just to mention one) that is much better/faster/less complicated that VRRP which further enhances Link and IP default gateways redundancy across two VSX switches.
Original Message:
Sent: Jan 15, 2023 04:47 AM
Subject: Why is VSX considered stacking
In that case what is the advantage of using VSX vs VSF?
Original Message:
Sent: Jan 10, 2023 07:44 PM
VSX pairs two switches. Some of the functions of of the pair operate much like you would expect from a traditional stack, however the control plane is distributed which makes the pair more resilient (like a cluster, if you like).
Despite the options of reference, VSX is awesome.
Original Message:
Sent: Jan 07, 2023 04:47 AM
In stacking (at least from my cisco knowledge), there is 1 logical switch and multiple physical.
But in VSX,
Multiple physical switches have different management ip.
Different switches cannot "see" one another.
So why is VSX considered stacking?
VSF is stacking I can argee though.
