Why my device( Laptop ) is not able to connect to Aruba-135 on 802.11N? (SOLVED)
  • 1.  Why my device( Laptop ) is not able to connect to Aruba-135 on 802.11N? (SOLVED)
    Posted Feb 02, 2015 02:12 AM
    Hi everyone,
    Pardon me if i'm posting at the wrong page.
    I am having a problem getting my device to connect to ARUBA-135 using 802.11N. My laptop's wireless adapter is Atheros AR5B97.
    I noticed that when connected using 802.11G , the maximum speed is only 54mbps.
    Would like to find out what is the correct settings needed to let my device connect to ARUBA using 802.11N.
    Thanks in advance.
  • 2.  RE: Why my device( Laptop ) is not able to connect to Aruba-135 on 802.11N? (SOLVED)
    Posted Feb 02, 2015 02:45 AM
    What security type are you using?
    Tim
  • 3.  RE: Why my device( Laptop ) is not able to connect to Aruba-135 on 802.11N? (SOLVED)
    Posted Feb 02, 2015 02:59 AM
    Tim
    Hi Cappalli,
    Are you talking about this ?
  • 4.  RE: Why my device( Laptop ) is not able to connect to Aruba-135 on 802.11N? (SOLVED)
    Posted Feb 02, 2015 03:18 AM
    Check here once..
    Wireless adpater property
    One more things you should use WPA2-AES..
    here something for your reference...
    http://www.howtogeek.com/204697/wi-fi-security-should-you-use-wpa2-aes-wpa2-tkip-or-both/
  • 5.  RE: Why my device( Laptop ) is not able to connect to Aruba-135 on 802.11N? (SOLVED)
    Posted Feb 02, 2015 03:34 AM
    Hi Suman,
    Thank you for your contribution. I had just check the properties of my network adapter, it does not have the same properties as the one you showed me.
    A little experiment i have done was to try connecting my laptop to a D-link router and its able to connect on wireless N.
    The top image is settings when connected to D-Link Router. Bottom is when connected to Aruba
    Thanks. Really appreciate all the help.
  • 6.  RE: Why my device( Laptop ) is not able to connect to Aruba-135 on 802.11N? (SOLVED)
    Posted Feb 02, 2015 04:38 AM
    The following things you can try..
    1. Make sure you are in 5Ghz band, and 40MHz channel.
    2. Check wheather any a/b/g client is connected to the same SSID.
    3.In IAP monitoring tab, click on your user name and check on which channel & type you are connected.
    4. Make sure your uplink is 1000mbps.
    5. Last thing, please update your wireless adapter.
    http://www.connect802.com/80211n_channels.htm
    NOTE: Don't try these in production. [better you check in lab]
  • 7.  RE: Why my device( Laptop ) is not able to connect to Aruba-135 on 802.11N? (SOLVED)
    Posted Feb 02, 2015 06:51 AM
    Are the drivers up to date?
    Tim
  • 8.  RE: Why my device( Laptop ) is not able to connect to Aruba-135 on 802.11N? (SOLVED)
    Posted Feb 02, 2015 10:03 PM
    Hi Tim and Suman,
    I had updated my wireless adapter to the latest.
    Thank you guys so much! It is connecting using 802.11N after i patched the wireless adapter.
