Why sometimes cannot modify settings using GUI? Have to use command line
  • 1.  Why sometimes cannot modify settings using GUI? Have to use command line
    Posted May 19, 2016 02:46 PM
    Hi , we have 2 controllers which are configured as Master/standby. Now sometimes cannot change settings on master controller through GUI, have to use command line, like radius server IP address. Please advise. Thanks in advance.
  • 2.  RE: Why sometimes cannot modify settings using GUI? Have to use command line
    Posted May 19, 2016 03:06 PM
    The standby controller cannot change the global configuration.  Only the current master can do that.
  • 3.  RE: Why sometimes cannot modify settings using GUI? Have to use command line
    Posted May 19, 2016 03:10 PM
    Thanks for reply.
    We always tried to change setting on master controller, but cannot modify radius server ip address .. but can do it through command line. Very strange
  • 4.  RE: Why sometimes cannot modify settings using GUI? Have to use command line
    Posted May 19, 2016 04:28 PM
    I have no problems modifying the "host" parameter, which is the ip address through the GUI.  Is that what you are talking about?
  • 5.  RE: Why sometimes cannot modify settings using GUI? Have to use command line
    Posted May 22, 2016 10:34 AM
    thanks for your kind reply.
    Yes, I wanted to change radius server IP address, cound not change it through master controller GUI, and can do it using command line. Do we need to disconnect the AP first?  Please advise.
  • 6.  RE: Why sometimes cannot modify settings using GUI? Have to use command line
    Posted May 22, 2016 10:36 AM
    There is no reason why you would not be able to do that on the master.  If you are having problems, please open a TAC case.
