Wi-Fi authentication with passcode only
  • 1.  Wi-Fi authentication with passcode only
    Posted Feb 22, 2016 10:05 AM
    Dear all,
    We have Aruba 3600 controller with 6.3.1.6 OS and several AP105 access points.
    End users use Active Directory username & password to authenticate on Wi-Fi (Employee SSID); whereas for Guest user we generate username/password which they tap it on the captive portal (Guest SSID).
    Is there anyway to create a separate SSID and make it authenticate with passcode only i.e. like we have in residential broadband router.
    Any help would be much appreciated, thank you.
  • 2.  RE: Wi-Fi authentication with passcode only
    Posted Feb 22, 2016 10:09 AM
    WPS is not possible in an enterprise network.
    Sent from Nine
  • 3.  RE: Wi-Fi authentication with passcode only
    Posted Feb 22, 2016 12:16 PM
    @bickyz wrote:
    Dear all,
    I assume this is for guest users and you want WPA2-PSK ?  This is possible in the ssid-profile.  Make sure the aaa-profile assigned to the vap has default-psk as the dot1x profile as well.
