Wi-Fi client segregation per SSID
  • 1.  Wi-Fi client segregation per SSID
    Posted Sep 25, 2014 05:18 PM
    We have IAP 255 devices.
    Is there an option for Wi-Fi client segregation, per SSID? That is to stop Wi-Fi clients from being able to communicate with each other on a given WLAN segment.
  • 2.  RE: Wi-Fi client segregation per SSID
    Posted Sep 25, 2014 05:43 PM
    (config)# deny-inter-user-bridging
    GUI
    System > General > Advanced Options > Deny inter-user bridging: enabled
  • 3.  RE: Wi-Fi client segregation per SSID
    Posted Sep 25, 2014 07:01 PM
    Is that global or per SSID?
  • 4.  RE: Wi-Fi client segregation per SSID
    Posted Sep 25, 2014 09:12 PM
    Sorry, didn’t see that you were asking about per-SSID.
    For that, you just enter the command under the SSID profile.
    (Instant AP)(config)# wlan ssid-profile <ssid-profile>
    (Instant AP) (SSID Profile <ssid-profile>)# deny-inter-user-bridging
    (Instant AP) (SSID Profile <ssid-profile>)# end
    (Instant AP)# commit apply
  • 5.  RE: Wi-Fi client segregation per SSID
    Posted Sep 26, 2014 05:27 PM
    This is very useful though I can't figure out how to configure profiles which have spaces in their profile names.. I'm certain it's something simple.
    Can someone shed some light on this?
  • 6.  RE: Wi-Fi client segregation per SSID
    Posted Sep 27, 2014 10:23 AM
    put them in quotes perhaps "name with space" ?
    or try tab completion and see if that makes it work.
  • 7.  RE: Wi-Fi client segregation per SSID
    Posted Sep 25, 2014 08:50 PM
    cinfig this gobal but it have in virtual ap in advancement tab for ssid
