Wifi Auto-Configuration Tool with hidden ssid
  • 1.  Wifi Auto-Configuration Tool with hidden ssid
    Posted Sep 16, 2013 04:35 AM
    Hi all,
    Is there anyone know what is the command for enable "Connect even if the network is not boardcasting" with Aruba Wifi Auto-Configuration Tool ?
  • 2.  RE: Wifi Auto-Configuration Tool with hidden ssid
    Posted Sep 16, 2013 07:33 AM
    That checkmark is when the SSID is hidden.  If you want to hide your SSID,
    (config)# wlan ssid-profile <name>
          (config)# hide-ssid
    I would recommend against this practice however.  Is there a reason you wish to do this?
  • 3.  RE: Wifi Auto-Configuration Tool with hidden ssid
    Posted Sep 16, 2013 08:18 AM
    Our customer want to hide the SSID base on their security policy.
    And they want to let the wireless users can setup the wireless profile on their device with one click.
    They create the bat file with the command as below:
    ArubaWifiCfg_Vista.exe -add /SSID:WiFi /Authentication:WPA2 /Encryption:AES /EAPType:PEAP /InnerAuthentication:GTC /EnableFastReconnect:TRUE /ValidateServerCert:FALSE >NUL
    But it won't enable "Connect even if the network is not boardcasting".
  • 4.  RE: Wifi Auto-Configuration Tool with hidden ssid
    Posted Sep 16, 2013 09:44 AM
    Group policy is the best way to do this.  The autoconfiguration tool does not have that switch.
    Group policy does not have an EAP-GTC option.  Are you also using EAP-GTC?
  • 5.  RE: Wifi Auto-Configuration Tool with hidden ssid
    Posted Sep 17, 2013 04:38 AM
    Yes, we're using EAP-GTC.
