last person joined: 10 hours ago
Wifi Calling Verizon not working IAP 225 8.3.0.1
  • 1.  Wifi Calling Verizon not working IAP 225 8.3.0.1
    Posted Jul 11, 2018 07:35 AM
    WiFi calling for Verizon isn't working when connected to my IAP 225 running 8.3.0.1; however, it will work when connected to a Desktop hotspot connected to the same network. I've taken a few packet caps, 1 at the router showing the failure, and 1 using the desktop hotspot showing a successful connection to wifi calling.
    Desktop AP SuccessDesktop AP SuccessIAP 225 FailingIAP 225 Failing
  • 2.  RE: Wifi Calling Verizon not working IAP 225 8.3.0.1
    Posted Jul 11, 2018 10:43 AM
    It looks like possibly an MTU related issue.
    From the desktop AP, the SA_INIT starts, there's an initial Initiator Request that is responded to, so a retry with smaller payload. The setup continues with the smaller frame size.
    On the AP225, the SA_INIT starts with a response back from Verizon, the client attempts to start with the larger frame size, but never retries with a smaller payload.
  • 3.  RE: Wifi Calling Verizon not working IAP 225 8.3.0.1
    Posted Jul 11, 2018 05:50 PM
    This was the issue. I have jumbo frames set on my router. Dropped the MTU to 1500 on all interfaces and wifi calling is back, even through it worked for 6 months before.
