Wifi client unable to ping it's default gateway, and WLC can not ping User-Vlan Gateway
  • 1.  Wifi client unable to ping it's default gateway, and WLC can not ping User-Vlan Gateway
    Posted Jan 09, 2020 04:04 AM
    WLC is Aruba 7205 and APs are 305 ,, VRRP is configured and working fine, Wifi Cleints are getting IP address from vlan-24 as designed ...but clients can not access netwokrk ,even can not ping their gateway which is vlan-24 ( 10.50.27.254)
    any suggessions please
    re,
    Anvar
  • 2.  RE: Wifi client unable to ping it's default gateway, and WLC can not ping User-Vlan Gateway
    Posted Jan 09, 2020 07:56 AM
    What role do the authenticated clients get?
    Have you allowed traffic in that role?
  • 3.  RE: Wifi client unable to ping it's default gateway, and WLC can not ping User-Vlan Gateway
    Posted Jan 09, 2020 10:32 AM
    the Role assigned is "authenticated"
      Its a new installation ,, so by default the traffic have to be allowed ,, am i right ?
    re,
    Anvar
  • 4.  RE: Wifi client unable to ping it's default gateway, and WLC can not ping User-Vlan Gateway
    Posted Jan 10, 2020 08:02 AM
    If you don't have the basics working, it is really hard to help you in this forum with limited information. It's probably something simple, and if you work with your partner or Aruba Support it is probably much faster to get to a solution and working configuration.
    From what I have seen in your different posts it can be the uplink configuration from the controller, the port and VLAN trusts, LACP, to start with. With access to the system for your partner or Support, it is probably easy to run the relevant commands to find and solve the issue.
