WIFI Password Encryption
  • 1.  WIFI Password Encryption
    Posted Feb 03, 2015 04:49 AM
    How to encrypt WIFI password for users? Is there any option available in aruba Instant?
    Is there any option available to set the download limit for some users?
    Thanks & Regards.,
    Srinivas.
  • 2.  RE: WIFI Password Encryption
    Posted Feb 03, 2015 04:56 AM
    • If you are using secure SSID the password is always encrypted.
    • You can limit bandwidth for users in Instant, not download limit.
    for that you have to use Clearpass.
  • 3.  RE: WIFI Password Encryption
    Posted Feb 03, 2015 05:43 AM
    Hi Suman,
    How to configure Secure SSID? I cannot find any option while configuring WIFI in aruba.
    Presently we are using Radius Server, there is no issue but network speed has been reduced & we are getting DNS Conflicts also.
    Regards.,
    Srinivas.
  • 4.  RE: WIFI Password Encryption
    Posted Feb 03, 2015 07:07 AM
    Can you be more specific? You say you're using a radius server already, so what are you trying to configure?
    Tim
  • 5.  RE: WIFI Password Encryption
    Posted Feb 03, 2015 07:21 AM
    As i told you previously presently we are using radius server & we are having the issues like DNS failovers & the speed of the network is also very slow. So we are planning to shift the network to WPA/WPA2.
    If we configure normally means for laptop users the WIFI preshared key is going to be visible. But our requirement is to protect that Key/Password.
    Regards.,
    Srinivas.
  • 6.  RE: WIFI Password Encryption
    Posted Feb 03, 2015 07:56 AM
    If PSK security is a concern, then you will need to use 802.1X (PEAP or EAP-TLS)
    Tim
  • 7.  RE: WIFI Password Encryption
    Posted Feb 03, 2015 11:42 PM
    Hi Tim,
    How to configure the wifi with 802.1x in Aruba Instant. We have to use enterprise & we need a radius server right? If we use radius server the network is becoming very slow.
    Regards.,
    Srinivas.
  • 8.  RE: WIFI Password Encryption
    Posted Feb 03, 2015 11:46 PM
    You can either use an external radius server (my recommendation) or the Instant can perform RADIUS duties.
    What is your existing radius server?
    Tim
  • 9.  RE: WIFI Password Encryption
    Posted Feb 04, 2015 06:38 AM
    Presently we have configured Radius server in our own server.
    You replied that the Instant can itself perform the Radius duties How?
    Regards.,
    Srinivas.
  • 10.  RE: WIFI Password Encryption
    Posted Feb 04, 2015 07:03 AM
    Use internal radius server and just add user. Thats all
  • 11.  RE: WIFI Password Encryption
    Posted Feb 04, 2015 07:10 AM
    What kind of RADIUS server do you have?
    Tim
  • 12.  RE: WIFI Password Encryption
    Posted Feb 17, 2015 05:00 AM
    Hi Tim,
    Sorry for delay.
    I have configured a radius server in windows server 2012 & that has been linked up with Aruba Network. The issue is with firewall & now it has been resolved.
    Thanks & Regards.,
    Srinivas.
  • 13.  RE: WIFI Password Encryption
    Posted Feb 04, 2015 02:25 AM
    As per my knowledge that is not because of radius server, might be some other issue . [Like interference, Uplink misconfiguration]
  • 14.  RE: WIFI Password Encryption
    Posted Feb 03, 2015 11:45 AM
    i would start troubleshooting that first. WPA2 enterprise authentication works fine for many deployments so if it doesn't for you there probably is something wrong that can be fixed.
    what exactly is a DNS failover? and how did you conclude that the wireless network is slow?
