WiFi Uplink for IAP-325
  • 1.  WiFi Uplink for IAP-325
    Posted Feb 11, 2016 03:47 PM
    I'm currently failing to set up a WiFi uplink with an IAP-325. After some while I noticed this hint in the documentation:
    The Wi-Fi uplink is supported on all the IAP models, except for the 802.11ac AP models (IAP-2xx Series access points). However only the master IAP uses this uplink. The Wi-Fi allows uplink to open, PSK-CCMP, and PSK-TKIP SSIDs.
    What does this mean for the IAP-325? Does it support WiFi uplink?
  • 2.  RE: WiFi Uplink for IAP-325
    Posted Feb 11, 2016 03:48 PM
    WiFi uplink is not supported on 802.11ac access points.
  • 3.  RE: WiFi Uplink for IAP-325
    Posted Feb 12, 2016 03:07 PM
    Although it's not what I wanted to hear: Thank you for the clarification.
  • 4.  RE: WiFi Uplink for IAP-325
    Posted Feb 13, 2016 11:13 AM
    is this subject to change at some stage or just how it is going to be?
