last person joined: 7 hours ago
WiFi-Uplink - Hotel WiFi
  • 1.  WiFi-Uplink - Hotel WiFi
    Posted Feb 21, 2020 07:07 AM
    Hi!  I use an Aruba 303H to connect to hotel wifi when traveling so that I can easily connect my apple tv to the internet.  Last few trips I've found that the AP will work for 20-30 mins and then begin having connectivity issues.  I've called the hotel support and they always ask me for the MAC address of the AP so they can whitelist it.  I've been giving them the MAC address of the VC... but that hasn't solved the problem.  How do I know which MAC address is being used for the WiFi-uplink connection?
    The 303H is running 8.6.0.2.
    Niten
  • 2.  RE: WiFi-Uplink - Hotel WiFi
    MVP GURU
    Posted Feb 21, 2020 08:45 AM
    Are you doing a source NAT for anything that's using the AP also? In other words make all traffic look like its coming from the AP its self, and not a device behind it?
  • 3.  RE: WiFi-Uplink - Hotel WiFi
    Posted Feb 21, 2020 01:56 PM
    Hi!,
    I’m configuring the 303H in NAT mode so it’s hiding the devices attaching to it from the hotel wifi network.
    Niten
  • 4.  RE: WiFi-Uplink - Hotel WiFi
    MVP GURU
    Posted Feb 21, 2020 02:37 PM
    OK great. The MAC address that you would want to give to them would be the Wired MAC address of the port you are using for uplink.
  • 5.  RE: WiFi-Uplink - Hotel WiFi
    Posted Feb 22, 2020 09:47 AM
    Hi!  I'm not using a physical connection.  I'm using WiFi-Uplink to connect to the hotel network.  What MAC address should I use in that scenario?
    Niten
  • 6.  RE: WiFi-Uplink - Hotel WiFi
    Posted Feb 22, 2020 05:05 PM
    it will be MAC address of the WiFi radio of your AP-303H
  • 7.  RE: WiFi-Uplink - Hotel WiFi
    Posted Feb 22, 2020 07:29 PM
    Makes sense. How do I determine which radio is connecting to the hotel WiFi and how do I get its MAC address?
  • 8.  RE: WiFi-Uplink - Hotel WiFi
    Posted Feb 23, 2020 06:02 PM
    the Wireless MAC address should be printed at the back of the AP-303H
  • 9.  RE: WiFi-Uplink - Hotel WiFi
    Posted Feb 25, 2020 11:47 AM
    Hi There!
    Is there a way I can get that information from the CLI or GUI?
    Niten
  • 10.  RE: WiFi-Uplink - Hotel WiFi
    Posted Feb 25, 2020 08:27 PM
    Dear Niten,
    Referring to the post
    https://community.arubanetworks.com/t5/Controllerless-Networks/WiFi-Uplink-feature-with-Instant-8-5/td-p/534619
    It highlights the process. Please see the snapshot of the command, this should be the mac address of your AP which the hotel should whitelist.
    sh wifi-uplink auth
    ---------------------------------------------------------------------- wifi uplink auth log: ---------------------------------------------------------------------- [5853]1556294443.043244: wpa_supplicant v2.6 [5853]1556294443.043369: random: Trying to read entropy from /dev/random [5853]1556294443.043463: Successfully initialized wpa_supplicant [5853]1556294489.360465: Priority group 1 [5853]1556294489.360527: id=0 ssid='SG9' [5853]1556294489.360652: Add interface aruba101 to a new radio N/A [5853]1556294489.360777: aruba101: Own MAC address: c8:b5:ad:3c:ae:21 [5853]1556294489.360840: aruba_driver_set_key 0x5f1484 0x5f153c [5853]1556294489.360933: set key: alg 0 key_id 0 tx 0 addr (nil) seq_len 0 key_len 0 [5853]1556294489.361027: aruba_driver_set_key 0x5f1484 0x5f153c [5853]1556294489.361121: set key: alg 0 key_id 1 tx 0 addr (nil) seq_len 0 key_len 0 [5853]1556294489.361214: aruba_driver_set_key 0x5f1484 0x5f153c [5853]1556294489.361277: set key: alg 0 key_id 2 tx 0 addr (nil) seq_len 0 key_len 0 [5853]1556294489.361402: aruba_driver_set_key 0x5f1484 0x5f153c [5853]1556294489.361464: set key: alg 0 key_id 3 tx 0 addr (nil) seq_len 0 key_len 0 [5853]1556294489.361558: aruba101: RSN: flushing PMKID list in the driver
  • 11.  RE: WiFi-Uplink - Hotel WiFi
    MVP GURU
    Posted Feb 22, 2020 05:11 PM
    Oh my bad, I assumed it was a wired connection.
