Wildcard cert
  • 1.  Wildcard cert
    Posted Dec 13, 2016 01:05 PM
    Hi all,
    We are changing Captive Portal certificat on our IAP clusters from Aruba default one to a wildcard one. After loading new cert onto a cluster we will have to change a field on ClearPass displaying new hostname (CA used to create certificate).
    Two questions: a) where on ClerPass should we change hostname, and b) as we are using wildcard cert can we change it just into "*.domain.co.uk"?
    AlanFord
  • 2.  RE: Wildcard cert
    Posted Dec 13, 2016 01:20 PM
    Did you take a look at this:
    https://community.arubanetworks.com/t5/Controller-less-WLANs/ArubaOS-Default
    -Certificate-Revocation-FAQ-Instant/ta-p/275814
  • 3.  RE: Wildcard cert
    Posted Dec 13, 2016 01:42 PM
    @AlanFord wrote:
    Hi all,
    AlanFord
    Two things:
    Wildcard certificates for captive portal are supported on InstantOS 4.3.0.0 and beyond, not before.
    The article here:  http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-configure-ClearPass-Guest-Amigopod-web-login-when-using/ta-p/176438 describes what you would change in ClearPass.  I know it says controller-based, but the ClearPass mechanism is the same.
  • 4.  RE: Wildcard cert
    Posted Dec 14, 2016 05:06 AM
    Thanks Colin,
    Great link. We are running on InstantOS 6.1, so that should be OK.
    AlanFord
