Wildcard Certificate - ClearPass
This thread has been viewed 54 times
  • 1.  Wildcard Certificate - ClearPass
    Posted May 18, 2020 04:27 PM
    Customer recently bought the ClearPass and moving Guest solution from Controller to ClearPass. They asking me to use existing wildcard certificate which is using controller based Guest solution to ClearPass guest solution  (SSL certificate).
    Could somebody confirm, can we use wildcard certificate for ClearPass guest solution.
    Thank you in advance.
  • 2.  RE: Wildcard Certificate - ClearPass
    Posted May 18, 2020 11:06 PM
    Yes. You can use a wildcard for CPPM guest.
  • 3.  RE: Wildcard Certificate - ClearPass
    Posted Aug 25, 2020 07:27 PM
    Would a wildcard cert be supported for the Radius Server certificate?
    I'm being asked basically, if instead of creating 3 different certs (Radius, HTTPS, RadSec) - we can just do one wildcard cert.
  • 4.  RE: Wildcard Certificate - ClearPass
    Posted Aug 25, 2020 08:58 PM
    You should not issue a wildcard certificate for radius authentication, no.
