Wildcard Certificate with Captive portal
This thread has been viewed 128 times
  • 1.  Wildcard Certificate with Captive portal
    Posted Aug 07, 2017 04:48 AM
    Import comercial wildcard certificate to the aruba controller, but when I try to connect captive portal SSID, Why does it show that certificate untrust (captive-portal.example.com)?
  • 2.  RE: Wildcard Certificate with Captive portal
    Posted Aug 07, 2017 08:36 AM
    Are you trying to access an HTTPS site?
  • 3.  RE: Wildcard Certificate with Captive portal
    Posted Aug 07, 2017 09:45 AM
    No. I try to access http site, it do redirect to captive-portal.example.com to take authentication.
    Wildcard from Digicert
  • 4.  RE: Wildcard Certificate with Captive portal
    Posted Aug 07, 2017 09:48 AM
    Does your captive portal server have a valid cert? Is the captive portal server whitelisted in your pre-auth captive portal profile?
  • 5.  RE: Wildcard Certificate with Captive portal
    Posted Aug 07, 2017 08:39 AM
  • 6.  RE: Wildcard Certificate with Captive portal
    Posted Aug 08, 2017 04:54 AM
    The name for a wildcard should be captiveportal-login.<name of your wildcard> instead of captive-portal.
    See: https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-does-Aruba-Controller-work-with-wild-card-certificate-for/ta-p/203199
