Will Mobility Controller 3600 be compatible with 802.11ac
  • 1.  Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Mar 28, 2013 09:43 AM
    Will the MC 3600 be compatible with 802.11ac AP ?
    If yes, in which conditions ?
    Thanks in advance.
    #3600
  • 2.  RE: Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Apr 03, 2013 11:31 PM
    The 3600 will support the 802.11ac APs when released. I'm not sure what you mean though by 'which conditions'?
  • 3.  RE: Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Apr 15, 2013 11:41 AM
    Sorry for the delay.
    I tough about the rate capacity for this controller with 4 gigabit links, so how many Lan connected AP 802.11ac will be supported at a time ? Compared to the 128 AP 802.11n.
    Sylvain.
  • 4.  RE: Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Apr 15, 2013 11:53 AM
    My understanding is the AP limit won't change, but yes if you are planning on running in tunnel-mode, you would be limited to a 4G uplink to the core. Depending on what your security and deployment requirements are, you could look at running APs in other modes. There will likely be a large amount of additional information coming out closer to launch.
  • 5.  RE: Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Apr 16, 2013 11:26 AM
    Thanks for your feedback i will wait for the official launch of 802.11ac support and the recomandations form ARUBA for their controllers.
    Thanks you.
  • 6.  RE: Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Jan 16, 2014 11:03 AM
    I reply to a deal and i need approximately 30 access points supporting the 802.11ac protocol.
    But today, only the MC 7200 can support officially this protocol and there is no communication for the MC 3600 at this subject.
    What is the official position of Aruba?
    Thanks in advance for your reply.
  • 7.  RE: Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Jan 16, 2014 11:12 AM
    You ought to start a new thread for new questions really...
    3200 will support 32 APs.
    Here's the Aruba controller matrix: http://www.arubanetworks.com/pdf/products/matrix-mobility-controller.pdf
    Cheers
    J
  • 8.  RE: Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Jan 16, 2014 11:46 AM
    Thank for your reply, but my question is the same that the thread:
    Does the MC 3600 be compatible to manager AP in 802.11ac?
    I know the limit of this product.
  • 9.  RE: Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Jan 16, 2014 11:57 AM
    Yes they will.
    The AP220 (which support 802.11ac) series require minimum ArubaOS version 6.3. This version is supported all 3000 series controllers.
  • 10.  RE: Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Jan 16, 2014 12:05 PM
    Ok thanks.
    Is there an official communication which will confirm your comments.
  • 11.  RE: Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Jan 16, 2014 12:06 PM
  • 12.  RE: Will Mobility Controller 3600 be compatible with 802.11ac
    Posted Jan 16, 2014 12:16 PM
    The AP225 release notes specify ArubaOS 6.3.
    http://www.arubanetworks.com/pdf/products/DS_AP220Series.pdf
    ArubaOS 6.3 release notes show controller supported.
    Here's what's available to download for version 6.3
