Will not boot to Partition 1 after upgrade
This thread has been viewed 22 times
  • 1.  Will not boot to Partition 1 after upgrade
    Posted Mar 19, 2012 04:16 PM
    I recently upgraded Partition 1 to 6.1.2.6 following the proper procedure and with the correct amount of memory and storage. I am now trying to reboot the controller to Partition 1 but it will not take. I have set the boot partition and restarted inside the GUI and from the CLI. Any ideas or suggestions would be greatly appreciated.
  • 2.  RE: Will not boot to Partition 1 after upgrade
    Posted Mar 19, 2012 04:34 PM
    When you say it will not "Take" what are the steps you take and what happens?
  • 3.  RE: Will not boot to Partition 1 after upgrade
    Posted Mar 20, 2012 09:41 AM
    As I mentioned in my post, after upgrading Partition 1, I set the default boot partition to Partition 1 and rebooted. The controller
    continues to boot to Partition 0. I have tried these steps both in the GUI and in CLI. It was at a proper previous version to make the
    upgrade and there was enough memory and storage for the upgrade. Any ideas?
  • 4.  RE: Will not boot to Partition 1 after upgrade
    Posted Mar 20, 2012 09:56 AM
    - What controller platform is this?
    - What are you upgrading from?
    - What method are you using to upgrade and did it finish?
    When you upgrade a partition, the boot partition is automatically set to that partition, so you should only have to reboot to switch to that code.
  • 5.  RE: Will not boot to Partition 1 after upgrade
    Posted Mar 20, 2012 10:15 AM
    -3400
    -6.0.1.3
    -FTP and it finished successfully
    Yeah usually it does switch to the partition you upgrade, but in this instance it did not. So I manually set it. Could that mean there is an issue with that partition? Should I upgrade or downgrade to a different version and try again?
  • 6.  RE: Will not boot to Partition 1 after upgrade
    Posted Mar 20, 2012 10:16 AM
    You should type "show image version" to make sure the upgrade was successful.  The console log on the controller will also tell you if there are problems during bootup.
  • 7.  RE: Will not boot to Partition 1 after upgrade
    Posted Mar 20, 2012 10:20 AM
    Please refer to previous post! Upgraded from 6.0.1.3.
    This is the current image versions of the controller:
    (CO-W3400-MDF-01) #show image version
    Partition : 0:0 (/dev/hda1)
    Software Version : ArubaOS 6.0.1.3 (Digitally Signed - Production Build)
    Build number : 28554
    Label : 28554
    Built on : Tue May 31 14:53:42 PDT 2011
    Partition : 0:1 (/dev/hda2) **Default boot**
    Software Version : ArubaOS 6.1.2.6 (Digitally Signed - Production Build)
    Build number : 31653
    Label : 31653
    Built on : Fri Dec 23 16:56:44 PST 2011
  • 8.  RE: Will not boot to Partition 1 after upgrade
    Posted Mar 20, 2012 10:21 AM
    When you reboot, you should capture the console logs to see if anything is amiss.  If that does not work, please open a case with support.
  • 9.  RE: Will not boot to Partition 1 after upgrade
    Posted Mar 20, 2012 10:26 AM
    I will try to get out to that controller today and do this. Thanks for your help.
  • 10.  RE: Will not boot to Partition 1 after upgrade
    Posted Mar 21, 2012 11:09 AM
    Upgraded Partition 1 again only this time through a console connection. Upgrade was successful. Rebooted controller to Partition 1 successfully. Got to love the GUI; sometimes it works and other times not so much. Thanks again for your help.
  • 11.  RE: Will not boot to Partition 1 after upgrade
    Posted Oct 03, 2016 04:20 AM
    Sorry, wrong topic
