last person joined: 8 hours ago
Will the AP-505 work in an AP-105 environment
  • 1.  Will the AP-505 work in an AP-105 environment
    Posted May 28, 2020 05:31 PM
    Hello all.
    We currently have numerous AP-105 in our location that have work flawlessly. We are currently expanding our wireless coverage to handle wireless VoIP that we will be installing. My questions is will the AP-505 work with the AP-105 that we already have up and running? Or is this going to be an issue? Thanks in advance!
  • 2.  RE: Will the AP-505 work in an AP-105 environment
    Posted May 28, 2020 06:31 PM
    It better work! That is the exact scenario we had in mind when deciding to to allow and support AP-105 and AP-505 to run on the same (8.6 or later) code.
    Happy to hear that the AP-105 has been working well for you, but it has now been end-of-sale for almost 5 years. Time to consider an upgrade
  • 3.  RE: Will the AP-505 work in an AP-105 environment
    Posted May 29, 2020 01:01 AM
    Yes, you can.
    Model 105 is a long time support upto version 8.6.
    For recommended, you should to separate to two location for better performance.
  • 4.  RE: Will the AP-505 work in an AP-105 environment
    Posted Jun 01, 2020 07:21 AM
    I should clarify that it is actually an IAP-105. Is this still upgradable to the newest firmware?
  • 5.  RE: Will the AP-505 work in an AP-105 environment
    MVP EXPERT
    Posted Jun 01, 2020 07:46 AM
    An IAP-105 is different, the latest Instant code it will support is InstantOS 4.2 and the minimum supported firmware for an AP-505 is InstantOS 8.6
    https://www.arubanetworks.com/en-gb/support-services/end-of-life/#AccessPoints
    So unfortunately these will not form a cluster when operating as an IAP.
