Windows 10 Wireless Network Settings
  • 1.  Windows 10 Wireless Network Settings
    Posted Nov 12, 2017 01:43 PM
    I know this isn't an Aruba issue, per se, but if somebody knows the answer, I susepect that much of the Aruba Community will rejoice!
    In Windows 7, you can go to Control Panel - Network and Internet - Manage Wireless Networks, right click on an existing network, and edit settings.... such as 802.1X authentication methods, user/machine auth, etc.
    How do you get to that box for existing networks in Windows 10? I've found a way to get to it for networks you are currently connected to. But if you break something and can't connect, there doesn't seem to be a way to get to that configuration box.
    I've also discvered that you can go to the Network and Sharing Center, and click on "Set up a new connection or network"
    From there you can setup a new network, and adjust security/connection settings:
    But once you click OK, that box seems to be gone forever.
    Is there any way to get back there, if I'm not currently connected?
    Thank you.
  • 2.  RE: Windows 10 Wireless Network Settings
    Posted Nov 12, 2017 08:50 PM
    Unfortunately, no. You'd need to use the netsh commands.
  • 3.  RE: Windows 10 Wireless Network Settings
    Posted Nov 12, 2017 11:53 PM
    Windows 10 is automatically Wireless configuration. You do not need to do advanced settings as Windows 7.
  • 4.  RE: Windows 10 Wireless Network Settings
    Posted Nov 13, 2017 08:23 AM
    That's not true at all.
  • 5.  RE: Windows 10 Wireless Network Settings
    Posted Aug 27, 2018 08:03 AM
    kindly give us a solution i need to connect my pc with access point
    i need a configuration properly please
    thanks
  • 6.  RE: Windows 10 Wireless Network Settings
    Posted Aug 27, 2018 08:52 AM
    Without knowing how your wireless is configured, we cannot help you. Please open a separate thread about your issue.
  • 7.  RE: Windows 10 Wireless Network Settings
    Posted Aug 27, 2018 09:38 AM
    i need a network wireless setting
  • 8.  RE: Windows 10 Wireless Network Settings
    Posted Aug 27, 2018 11:32 AM
    You haven't given any information that we would need to give you advice on how to configure your Windows Client.
  • 9.  RE: Windows 10 Wireless Network Settings
    Posted Aug 28, 2018 02:11 AM
    I explained here i hope you get it,I have aruba access point and i have configured very well and all system working well just simply put the user id password it is connected like Macbook,Linux but the same setting in windows, click wifi put id password its mention on the screen unable to connect as i mention pitcure please check and let me know what is missing in my windows system,
    thanks
  • 10.  RE: Windows 10 Wireless Network Settings
    Posted Aug 28, 2018 04:30 AM
    Did you try different win10 computers?
    Are you using an external radius authentication server?
    If yes, what error do you see for Win10 authentication failure?
    The attached client error in your post will not help to determine the cause of failure. You need to debug the issue between the Client, IAP and authentication server.
  • 11.  RE: Windows 10 Wireless Network Settings
    Posted Aug 28, 2018 04:55 AM
    WHEN  I GOT COMPLAINT SOME ERROR ISSUE WITH CLIENT SO I TRY TO MY WINDOWS SYSTEM AND SEE THE SAME ERROR ONLY IN WINDOWS,
    I REALLY DONT UNDERSTAND THAT WHAT IS GOING ON AND WHERE ?
  • 12.  RE: Windows 10 Wireless Network Settings
    Posted Aug 28, 2018 05:39 AM
    Please open a support/tac ticket to debug the issue further.
  • 13.  RE: Windows 10 Wireless Network Settings
    Posted Aug 28, 2018 05:43 AM
    HAVE YOU GOT ANY SETTING FOR WINDOWS 10 ?
    PLEASE SHARE SOMTHING,
  • 14.  RE: Windows 10 Wireless Network Settings
    Posted Aug 28, 2018 05:57 AM
    You need to let us know how your wireless network (SSID) is configured to help you. Without knowing your wireless configuration, we will not be able to help you.
  • 15.  RE: Windows 10 Wireless Network Settings
    Posted Aug 28, 2018 06:22 AM
    I simply put enterprise , TLS, ID PASSWORD,
    THATS IT
  • 16.  RE: Windows 10 Wireless Network Settings
    I have configured my access point now its working well
    mac is working
    linux is working
    but
    windows is not working
  • 17.  RE: Windows 10 Wireless Network Settings
    Posted Nov 07, 2018 09:13 AM
    I know this is an old thread, but this is how you modify the profile properties in Win 10. I've had to do this several times to adjust the authentication method from machine to user.
    Press Windows +  X
    Select Control Panel
    Change View by to Small / Large Icons
    Click on Network and Sharing Centre
    Select your network connection (highlighted)
    Popup appears
    Click on Manage Wireless and you should be off and running.
