Windows 8.1 have and issue connecting to Aruba controller and android work normal?
  • 1.  Windows 8.1 have and issue connecting to Aruba controller and android work normal?
    Posted Aug 08, 2015 11:08 AM
    I am connecting my clearpass and controller to use 802.1x now android work normal but windwos 8.1 can not connect at all tried all thing no luck I have read something related to the PMK but they also said the new updates soolved it and now Im using version 6.4.2.5 (ArubaOS) so what may cause this and also how to disbale PMKID?
  • 2.  RE: Windows 8.1 have and issue connecting to Aruba controller and android work normal?
    Posted Aug 08, 2015 11:10 AM
    What does the auth-tracebuf show?
    Security logs?
    Do you see any request on your RADIUS server?
    Are you using a public or privately signed CA?
    Tim
  • 3.  RE: Windows 8.1 have and issue connecting to Aruba controller and android work normal?
    Posted Aug 08, 2015 11:46 AM
    yes ona ccess tracker gives yellow 9EAP transaction not completed
  • 4.  RE: Windows 8.1 have and issue connecting to Aruba controller and android work normal?
    Posted Aug 08, 2015 12:22 PM
    Can you provide answers to the other questions?
    Tim
  • 5.  RE: Windows 8.1 have and issue connecting to Aruba controller and android work normal?
    Posted Aug 08, 2015 12:38 PM
    This is the show auth-trace
    Aug  8 10:43:42  eap-id-resp           ->  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                1    14   employee1
    Aug  8 10:43:42  rad-req               ->  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                204  201
    Aug  8 10:43:47  dot1x-timeout          *  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                1    3    server timeout
    Aug  8 10:43:47  dot1x-timeout          *  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                2    2    station timeout
    Aug  8 10:43:47  eap-id-req            <-  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                2    5
    Aug  8 10:43:48  station-down           *  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                -    -
    and for the certificate I'm using the self signed one
  • 6.  RE: Windows 8.1 have and issue connecting to Aruba controller and android work normal?
    Posted Aug 08, 2015 12:44 PM
    If the self signed cert installed on the clients?
    Tim
