Windows & CCPM radius for single SSID
  • 1.  Windows & CCPM radius for single SSID
    Posted Aug 13, 2014 09:23 AM
    I have two radius 1) Windows NPS 2) CPPM with two different domain
    They both radius have different user groups.
    Can use both radius for same ssid?
    If user is not in Windows NPS will controller check in CPPM for authentication? or how that will work?
    Thanks in advance.
  • 2.  RE: Windows & CCPM radius for single SSID
    Posted Aug 13, 2014 09:29 AM
    You would use match rules in your server group to match the domain to the RADIUS server.
    You could also proxy requests through ClearPass to your NPS server.
  • 3.  RE: Windows & CCPM radius for single SSID
    Posted Aug 13, 2014 09:41 AM
    Indeed, because if you don't, if the user is not known in the first server it will send a reject and after a reject it stops.
    The server fal through option is only valid when the first server is not reachable, then it will try to reach the following.
    EDIT: oops I meant fall through, fail through should do the trick
    but following Aruba's recommendation
    user guide 6.3 page 218 says:
    "Aruba recommends that you use server selection based on domain matching whenever possible"
  • 4.  RE: Windows & CCPM radius for single SSID
    Posted Aug 13, 2014 06:01 PM
    Yes, you can set the up so that if the user fails to authenticate on the first radius server in the radius group, it will fall through to the next one. I'm on mobile right now so I can't share a image. But it is possible
  • 5.  RE: Windows & CCPM radius for single SSID
    Posted Aug 14, 2014 06:05 AM
    Its pretty simple.
    Add the second radius server in respective ssid server group and select the "Fall through" checkbox.
  • 6.  RE: Windows & CCPM radius for single SSID
    Posted Aug 14, 2014 06:07 AM
    @nik-mh wrote:
    Its pretty simple.
    I made the same mistake, it is fail through and not fall through
