Wip Config - poblem with open networks
  • 1.  Wip Config - poblem with open networks
    Posted Feb 03, 2013 10:01 AM
    Hi To all
    i use a 3400 controller with aruba os 6.1.3.5.
    at the wip configuration i marked that im using open networks as valid.
    but, when i go to security on the dashboard, i see that my open network is classified as valid, but marked to containe.
    how can i disable automatic contaiment of open networks?
    see the attached profiles txt files.
    Thanx in advanced
    naor.
    #3400
    Attachment(s)
    txt
    un_auth_profile.txt   2 KB 1 version
    txt
    impersonation_profile.txt   599 B 1 version
    txt
    general_profile.txt   960 B 1 version
  • 2.  RE: Wip Config - poblem with open networks
    Posted Feb 03, 2013 10:23 AM
    Let's start with..  What are you trying to accomplish?
    There are  many options available, and sometimes they conflict.  If you can let me know what you want to do, we can lead you to the right configuration.
  • 3.  RE: Wip Config - poblem with open networks
    Posted Feb 03, 2013 03:51 PM
    Hi
    thank you for replying.
    i want to be able to connect to open networks in my office, while enabling WIP.
    once i enable WIP, i can't connect to an open network that is configured on the controller ,because it is automatically marked for contaiment (even though, i enabled open networks to be approved at the WIP wizard).
    if i configure wpa for that same network, its goes out of contaiment without any intervention from my side.
    i need to know what i have to configure in order to let open networks to be valid, but not contained.
    thankx in advanced.
    naor.
  • 4.  RE: Wip Config - poblem with open networks
    Posted Feb 03, 2013 04:04 PM
    Do you only want your OWN network to be Valid or all Open Networks?
     That would mean anyone who had an open mifi or hotspot would work...
  • 5.  RE: Wip Config - poblem with open networks
    Posted Feb 04, 2013 02:28 AM
    Hi
    I want my own network to work.
    once i enable WIP, the open network is valid, but contained for some reason.
    can u tell me why it's marked for contaiment automatically?
    Thankx in advanced
  • 6.  RE: Wip Config - poblem with open networks
    Posted Apr 12, 2013 09:11 AM
    same issue, the code version is 6.1.3.4
    I found when you reuse the wizard, the open encryption option still not checked, and I cannot find the CLI command
    the result is all "open" AP will be contain and even the APs have already pushed Valid AP class
    upgrading, see if same result..
    Kevin Zhu
  • 7.  RE: Wip Config - poblem with open networks
    Posted Apr 12, 2013 09:47 AM
    code 6.2.0.2 ,same issue (can not make Open network not be contained using WIP wizard)
    regards
    kevin
  • 8.  RE: Wip Config - poblem with open networks
    Posted Apr 12, 2013 09:50 AM
    Please open a support case to get that looked it.  We want to make sure you did not miss any steps.
