Wired 802.1X EAP-TLS on IAP
  • 1.  Wired 802.1X EAP-TLS on IAP
    Posted Nov 07, 2019 09:28 PM
    Hello, is there a way to do wired 802.1X using EAP-TLS and factory certificates on IAPs? I've only found PEAP.
  • 2.  RE: Wired 802.1X EAP-TLS on IAP
  • 3.  RE: Wired 802.1X EAP-TLS on IAP
    Posted Nov 18, 2019 07:33 PM
    Hi cjoseph, I upgraded to 8.5.0.4 and attempted to configure with the following result:
    FRM-IAP-01 (config) # ap1x tls tpm
    FRM-IAP-01 (config) # exit
    FRM-IAP-01# commit apply
    committing configuration...
    does not support tpm yet!
    It doesn't appear I can do this in the GUI either.
    Any clue when this will be available?
  • 4.  RE: Wired 802.1X EAP-TLS on IAP
    Posted Nov 18, 2019 08:44 PM
    What model access point is that?
  • 5.  RE: Wired 802.1X EAP-TLS on IAP
    Posted Nov 19, 2019 03:39 PM
    That happened on a 325.
  • 6.  RE: Wired 802.1X EAP-TLS on IAP
    Posted Jan 13, 2021 06:14 AM
    How did this case end?
    Greetings
    Bernd Borowski
