The wired AP profile (important to put in the VLAN and make it untrusted, ethernet interface link profile (used to set the speed and duplex of the link, but not really important, and the AAA profile parameters are subordinate or "daughters" of the Ethernet Interface X port configuration. If I have an enet port 1 configuration of "default" and I change the Wired AP profile under it to be untrusted (click apply), then go to the AAA profile and change it (click apply), I can then reuse that enet port 1 config of default on enet 2 port configuration and it will copy all of the wired ap profile, ethernet interface link profile and aaa profile config I made to enet2 on the RAP (rap2 does not have enet2, though).
Long story short, you can reuse the same ethernet interface X port profile, on all ports to achieve this result on all ports.
