Wired AppleTV associate to ap-group - Aruba OS 8
  • 1.  Wired AppleTV associate to ap-group - Aruba OS 8
    Posted Feb 23, 2020 10:22 AM
    Is there a way to auto-associate wired Airgroup servers?
    I went through the user guide of 8.x and found auto-association is applicable only for wireless AirGroup servers but not for wired Airgroup servers. Please correct me, if I am wrong. I am working on a similar deployment and found that after sometime iPhone device is able to discover wired Apple TV associated with other ap-group.
    In our setup, we don't use ClearPass and the controller is in standalone topology.
  • 2.  RE: Wired AppleTV associate to ap-group - Aruba OS 8
    Posted Feb 23, 2020 11:16 AM
    For wired devices, you would enter the wired mac address of the Apple TV into a server-based policy and then enter the ap-group you want it associated to using the server-based policy instructions here:  https://www.arubanetworks.com/techdocs/ArubaOS_86_Web_Help/Content/arubaos-solutions/airgroup/conf-argp-srbs-poli.htm?Highlight=airgroup%20policy
    For best performance, it is best to autoassociate to an ap-name and add a server-based policy to just an ap-name, instead of an ap-group, which consumes more cycles on the controller.
  • 3.  RE: Wired AppleTV associate to ap-group - Aruba OS 8
    Posted Feb 24, 2020 09:29 AM
    Thank you for the response!
    I will try the same and keep you posted.
  • 4.  RE: Wired AppleTV associate to ap-group - Aruba OS 8
    Posted Feb 26, 2020 03:23 AM
    As per your suggestion, I made changes. Please find the same below:
    (Aruba7030) [mynode] #show airgroup status
    AirGroup Information
    Feature               Status
    AirGroup mode         Distributed
    AirGroup Profile      TestAirgroup
    CPPM Profile
    Active domain
    MDNS                  Enabled
    DLNA                  Disabled
    Enforce Registration  Enabled
    IPV6                  Disabled
    AirGroup Service Information
    Service          Status
    default-airplay  Enabled
    (Aruba7030) [mynode] #show airgroup policy-entries
    AirGroup Device Policy Information
    Device             device-owner  shared AP-name  shared AP-FQLN  shared AP-group  shared users  shared groups  shared roles  CPPM-Req  CPPM-Resp  source  Auto-Associate  Neighborhood
    50:de:06:71:b4:74  N/A           APground        CLI                     No
    50:de:06:7e:12:9a  N/A           APfirst        CLI                     No
    But still, I am able to see the wired Airgroup server on another floor. I believe this might be happening because of Apple's bluetooth based discovery because Apple TV is visible at a particular location.
    From Apple TV side I changed Settings > AirPlay > AirPlay and switched from Everyone to Anyone on the Same Network. But still I am able to see wired Airgroup server on iPhone.
  • 5.  RE: Wired AppleTV associate to ap-group - Aruba OS 8
    Posted Feb 26, 2020 04:13 AM
    I validated it doesn't seem to be issue because of bluetooth based discovery. On the ground floor I can still see First-floor airgroup server with bluetooth disabled on my device.
  • 6.  RE: Wired AppleTV associate to ap-group - Aruba OS 8
    Posted Feb 26, 2020 04:21 AM
    Per-AP Airgroup is limited to being on an AP and its immediate neighbors.  If the AP you are on can see other APs, you will see the airgroup devices on those APs.
  • 7.  RE: Wired AppleTV associate to ap-group - Aruba OS 8
    Posted Feb 26, 2020 04:24 AM
    Thank you for the explanation!
    I tried the same with Ap-group as well but still no luck.
  • 8.  RE: Wired AppleTV associate to ap-group - Aruba OS 8
    Posted Feb 26, 2020 04:32 AM
    Please find the output for the same below:
    50:de:06:71:b4:74  N/A                                           Groundfloor        CLI                     No
    50:de:06:7e:12:9a  N/A                                           Firstfloor        CLI                     No
    Num Policy Entries:2
    (Aruba7030) [mynode] #write memory
    Saving Configuration...
    Configuration Saved.
    Feature               Status
    AirGroup Profile      RMZAirgroup
    CPPM Profile
    Active domain         Airgroup-Domain
    MDNS                  Enabled
    DLNA                  Disabled
    Enforce Registration  Disabled
    IPV6                  Disabled
    Service          Status
  • 9.  RE: Wired AppleTV associate to ap-group - Aruba OS 8
    Posted Feb 26, 2020 09:37 AM
    What version of ArubaOS 8 are you using?
  • 10.  RE: Wired AppleTV associate to ap-group - Aruba OS 8
    Posted Feb 26, 2020 09:42 AM
    We are on OS version 8.6.0.2
  • 11.  RE: Wired AppleTV associate to ap-group - Aruba OS 8
    Posted Oct 02, 2020 04:18 AM
    Hi, did you ever find a solution to this?
