still the same
how to know where the problem is?
[FMC-Mezz-A2]dis dot1x inter g5/0/1
Equipment 802.1X protocol is enabled
EAP authentication is enabled
EAD quick deploy is disabled
Configuration: Transmit Period 30 s, Handshake Period 15 s
Quiet Period 60 s, Quiet Period Timer is disabled
Supp Timeout 30 s, Server Timeout 100 s
Reauth Period 3600 s
The maximal retransmitting times 2
EAD quick deploy configuration:
EAD timeout: 30 m
The maximum 802.1X user resource number is 1024 per slot
Total current used 802.1X resource number is 0
GigabitEthernet5/0/1 is link-up
Handshake is disabled
Handshake secure is disabled
802.1X unicast-trigger is disabled
802.1X user-ip freeze is disabled
Periodic reauthentication is enabled
The port is an authenticator
Authentication Mode is Auto
Port Control Type is Port-based
802.1X Multicast-trigger is enabled
Mandatory authentication domain: fmcdom
Guest VLAN: NOT configured
Auth-Fail VLAN: NOT configured
Critical VLAN: NOT configured
Critical recovery-action: NOT configured
Max number of on-line users is 256
EAPOL Packet: Tx 519, Rx 85
Sent EAP Request/Identity Packets : 477
EAP Request/Challenge Packets: 0
EAP Success Packets: 0, Fail Packets: 29
Received EAPOL Start Packets : 31
EAPOL LogOff Packets: 0
EAP Response/Identity Packets : 34
EAP Response/Challenge Packets: 0
Error Packets: 0
Controlled User(s) amount to 0
