Original Message:
Sent: Apr 18, 2023 04:08 AM
Subject: Wired Authentication with EAP-TTLS not working
Hi
What is the error message under the Alerts tab?
EAP-TEAP for sure have benefits over EAP-TLS as you get the authentication of both the Windows computer and the user in the same auth request. But it can be a bit more challanging to configure the first time.
EAP-TLS is easier to configure, in Windows you don't select EAP-TLS instead the drop down have text "Microsoft: Smart card or other certificate".
If you intend to authenticate both computer and user, stay with TEAP. If only computer is enough you can also try to use EAP-TLS.
Is the Radius certificate issued by the same CA as the client certificate, or at least under the same root?
Best Regards
Jonas Hammarbäck
MVP 2023, ACCX #1335, ACX-Network Security, Aruba SME, ACMP, ACDP , ACEP, ACSA
Aranya AB
Original Message:
Sent: Apr 18, 2023 03:53 AM
Thanks Jonas,
Did that but still got the below:
Would I be missing anything else? I installed domain root cert on client PC already.
Do I need to install any other certs ?
Original Message:
Sent: Apr 18, 2023 03:08 AM
Hi
You have to add the TEAP method manually.
Select the user name to display in Access Tracker:
Add EAP-TLS as the Inner method
Best Regards
Jonas Hammarbäck
Aranya AB
Original Message:
Sent: Apr 18, 2023 02:59 AM
I dont have an option for EAP-TEAP on my clearpass as auth method.
Am i missing something?
Original Message:
Sent: Apr 17, 2023 08:35 AM
What is under the Alerts tab? Why use EAP-TTLS? Looks like the supplicant is configured for TEAP?
Original Message:
Sent: Apr 17, 2023 01:59 AM
Hi Folks,
Just looking for some guidance as to what I am getting wrong.
Windows client tries to autehnticate and gets the following error:
Not picking up auth source.
Windows client:
Are there a few things I have missing?
Does anyone have any docs or guides I can make ref to for end-end?
