Wired Authentication with multiple vendors and models
  • 1.  Wired Authentication with multiple vendors and models
    Posted Dec 13, 2018 11:49 AM
    Hi all,
    We're starting to test wired authentication using Clearpass. The plan is to to 802.1x --> MACAuth --> CP fall through. We currently have two switch vendors and several models in production and will likely add more. I'm wondering what the best practice is for creating services in Clearpass for this environment. The wired policy solution guide ihas been helpful.
    Would separate services get created for 802.1x, MACAuth and CP? Then duplicate that per vendor type? Or can this all be folded up into a single service called wired-auth?
    Thanks in advance!
    Mike
  • 2.  RE: Wired Authentication with multiple vendors and models
    Posted Dec 13, 2018 11:55 AM
    You’ll need 3 services at a minimum per vendor.
  • 3.  RE: Wired Authentication with multiple vendors and models
    Posted Dec 13, 2018 12:22 PM
    Thanks Tim. It was begining to seem this way but I wanted to verify.
    Best,
    Mike
