Wired captive portal
This thread has been viewed 16 times
  • 1.  Wired captive portal
    Posted Aug 09, 2019 10:05 AM
    I try to configure wired guest feature on aruba switch. I use DUR and I succefuly display captive portal on pc.
    I don’t realy know how build a service to authentitcate guest account.
    I followed Wired Policy Enforcement guide
    Portal URL : https://10.159.100.20/guest/portal.php
    I have a failure on access traker : ServiceClassification failed {No service matched}
    Can you help to ajust configuration please ?
    I attached screenshots of service.
    Thank you
  • 2.  RE: Wired captive portal
    Posted Aug 09, 2019 10:52 AM
    You need a web authentication service with a user-role CoA
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Wired captive portal
    Posted Aug 09, 2019 11:01 AM
    I have already a [ArubaOS Switching - Bounce Switch Port] in enforcement profil, it's not enough ?
    I change [ArubaOS Wireless - Bounce Switch Port] by  [ArubaOS Switching - Bounce Switch Port] but nothing change
  • 4.  RE: Wired captive portal
    Posted Aug 10, 2019 08:00 PM
    check this technote, hopefully it will help you ith the clearpass service configurations.
    https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/Wired-Enforcement-of-Local-and-Downloadable-user-roles/m-p/518927#M5481
