We don't see wired client detail like mac-address or ip address from Central. We can see wireless client details but not wired client. Gateway, IAP, switch are in same group but still we can't see wired client connected to switch. If wired client is directly connected to IAP 303H E0,E1,E2,E3, PORT it is visible . since E1 port of IAP 303H is connected to switch AND Client connected to switch than there is no visibility of wired client. Can somebody look into this.
What is the switch model in question? Are you doing any authentication on the switch port opposed to the wired port on the AP?
I presume you have an IAP-303H working as micro-branch (AKA, IAP-VPN) and that you have the switch connected to one of the ports in the AP. Is that correct?
If that's the case, is the IAP port set to untrusted?
How is the switch configured?
I'd just like to add I have the same issue.
2930F switches and AP-365's
no fancy configs as yet, out of the box, firmware updated and connected to Central in my scenario.
Wireless clients are visible straight away, just nothing on wired.
Thanks Victor,
No authentication as yet, will be adding Clearpass eventually to it, so hopefully will see data then if it can't be added before then.
How are the wireless AP's getting the info back to Central without any authentication?
Ryan
Enabling dhcp-snooping will allow you to see wired client ip's.
