Wired clients on APS(rap3, rap 109 etc) user table
  • 1.  Wired clients on APS(rap3, rap 109 etc) user table
    Posted May 24, 2013 11:58 PM
    Does anyone know why i need to make the port untrusted  and well using split tunnel for example to make it appear on the user table? if i make it trusted then it wont appear... why is that?
    Also i got an ip phone plugged to a rap3 here on my home and i see this
    172.17.7.12:-255/9 on the ESSID
    And my workstation
    172.17.7.12:0/1 on the ESSID
    Well when i saw my workstation i though oh its the port 0/1 and well my workstation is plugged to that port to the port 1 nice...
    But then i saw 172.17.7.12:-255/9 and i was like whats the 255/9?? its plugged to port 2
    Any ideas what is it?
    Cheers
    Carlos
  • 2.  RE: Wired clients on APS(rap3, rap 109 etc) user table
    Posted May 25, 2013 07:05 AM
    By marking a port untrusted, you are saying you want to identify the device.   This enables a AAA profile, with a role, thus the visibility of the client on the user table.  If you mark it trusted, then all traffic is allowed, no identification/authentication necessary.
    Your assessment of your workstation on port 1 is correct, thus the :0/1
    However, I am not sure what 255/9 is.   I just tried it on a RAP-3 and it shows up as 192.168.3.230:0/2.   Not sure where you are getting the 255/9 from.
  • 3.  RE: Wired clients on APS(rap3, rap 109 etc) user table
    Posted May 25, 2013 08:32 AM
    Thanks for the easy explanation Clembo!
    Im getting that info from the user table... look by yourselft
    The second one which give me that number is an Alcatel Ip Phone
    Cheers
    Carlos
  • 4.  RE: Wired clients on APS(rap3, rap 109 etc) user table
    Posted May 25, 2013 08:43 AM
    If i put it on tunnel mode untrusted it show it correctly
    But now i put it again on split tunnel i see that crazy number again
    Looks like a bug or something like it or what do you thin Chris?
    Cheers
    Carlos
  • 5.  RE: Wired clients on APS(rap3, rap 109 etc) user table
    Posted May 25, 2013 08:56 AM
    not sure; mine was in split-tunnel and showed properly; code is 6.2.0.2 on this controller.
  • 6.  RE: Wired clients on APS(rap3, rap 109 etc) user table
    Posted Sep 30, 2013 06:27 AM
    Hijacking the thread, will the local split tunneling work with the trusted option checked? Let's say I got a wired port for a local switch that I put in split tunneling and trusted and then I've got a printer on another wired port on my RAP5.
  • 7.  RE: Wired clients on APS(rap3, rap 109 etc) user table
    Posted Sep 30, 2013 07:48 AM
    A split tunneled port MUST be untrusted, because we get the initial role from the AAA profile attached.  That initial role and the firewall policies defines what traffic is tunneled and what traffic is bridged.
