Wired deployment query
  • 1.  Wired deployment query
    Posted Mar 04, 2019 05:17 PM
    I have a specific query for a customer.
    They have a common vlan for laptop,printer ,camera and creating separate vlan is not an option for them.
    Now eap tls is being proposed for laptops and rest all authenticate via mab . We use DHCP profiling and we will be using open mode for first 3 months .
    My query as we are not doing vlan enforcement, what parameter cppm will return as successfull eap-tls or successful mab ?
    We will be doing enforcement later after 3 months .but for open mode what is enforcement parameters or attribute even though enforcement does not block anything as we are using open mode and allow all initially
  • 2.  RE: Wired deployment query
    Posted Mar 04, 2019 05:26 PM
    What type of switch are you using ?
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Wired deployment query
    Posted Mar 04, 2019 05:27 PM
    We have both Cisco and hope in the customer network
  • 4.  RE: Wired deployment query
    I mean hpe
  • 5.  RE: Wired deployment query
    Posted Mar 04, 2019 05:58 PM
    If you are looking for more visibility you can return a user-role per use case (laptop , VoIP , etc)
    Thank you
    Victor Fabian
  • 6.  RE: Wired deployment query
    Posted Mar 04, 2019 06:00 PM
    I would recommend following the ClearPass Solution Guide for Wired Policy Enforcement.
