Wired Guest Access
  • 1.  Wired Guest Access
    Posted Mar 16, 2018 09:16 AM
    Hello everyone !
    A custumer wants that users do 802.1X authentication on the wired access with clearpass.
    If the 802.1X authrentication doesn't work ( for a guest user for example), then the user is redirected to the ClearPass captive portal.
    Can someone please explain to me how can I do that ?
    Thank's all for your help !
  • 2.  RE: Wired Guest Access
    Posted Mar 16, 2018 09:17 AM
    Did you look at the ClearPass Solution Guide for Wired Policy Enforcement?
  • 3.  RE: Wired Guest Access
    Posted Mar 16, 2018 09:52 AM
    Hello !
    Thank you very much for your reply.
    I read some parts of it. I found how to do 802.1X with wired access. i found how to do captive portal with the wired access.
    But I don't know how the fallback mechanism works : if 802.1X doesn't success, so we perform web auth...
  • 4.  RE: Wired Guest Access
    Posted Mar 16, 2018 09:54 AM
    It’s all on the switch side.
  • 5.  RE: Wired Guest Access
    Posted Mar 19, 2018 09:23 AM
    What kind of switches do you use?
    For Cisco you can do something like this:
    interface GigabitEthernet1/0/35
     switchport access vlan 100
     switchport mode access
     authentication host-mode multi-domain
     authentication order dot1x mab
     authentication priority dot1x mab
     authentication port-control auto
     authentication timer reauthenticate server
     mab
     dot1x pae authenticator
     dot1x timeout tx-period 10
     dot1x timeout supp-timeout 15
     dot1x max-reauth-req 1
     spanning-tree portfast
    MAB is the key there - as it's mac address bypass - which in essence is mac-auth.. So on failed dot1x it will do mab, and here you will return the attributes from Clearpass which triggers the redirect-acl. Once redirected and authenticated, you use Radius CoA to change the ACL for the client.
  • 6.  RE: Wired Guest Access
    Posted Mar 19, 2018 10:53 AM
    If you use aruba switches you can send an enforcement profile on authentication failure with the captive portal URL (based on HPE VSA's):
    Radius:Hewlett-Packard-Enterprise
    HPE-Captive-Portal-URL (24)
    http://<cppm-server>/guest/<guest-page>.php
    Be sure to enable captive portal in the switch.
    Also a couple of downloadable ACL's are required to block all traffic except dns, dhcp and 80/443 to clearpass.
  • 7.  RE: Wired Guest Access
    Posted Mar 19, 2018 11:00 AM
    If only there was a doc that covered this step by step ;)
  • 8.  RE: Wired Guest Access
    Posted Mar 19, 2018 10:57 AM
    Thank you all for your answer !
    The custumer have Extreme switches. I looked for documentation but I didn't find anything yet.
