Wired MDNS traffic
This thread has been viewed 160 times
  • 1.  Wired MDNS traffic
    MVP
    Posted Sep 19, 2021 05:14 PM
    Hello everyone,
    We upgraded from ArubaOS 6.5 (Master-local) to ArubaOS 8.7.1.4 (MM-MD01-MD02) a month ago. Ever since then, wireless users can not see wired MDNS/AirGroup servers. All of our VLANS exist on the controllers. We ported over the settings from the old config including BCMC opt ON for all VLANS. I know this setting being on can affect wired MDNS traffic but it was on before and it worked.
    TAC has no idea after multiple calls. Can anyone point us in the right direction?
    Nathan Kuhl
  • 2.  RE: Wired MDNS traffic
    Posted Sep 20, 2021 08:05 AM
    The way Airgroup works changed significantly between AOS6 and AOS8. Did you read the AirGroup Deployment Guide?
    Also, the documentation on AirGroup in the ArubaOS documentation is pretty good.
    If that is TAC's response, ask them to escalate your case to another engineer that does have an idea.
  • 3.  RE: Wired MDNS traffic
    Posted Sep 20, 2021 08:09 AM
    A few questions about how your setup
    Are you running in distributed or Centralized mode?
    How are wired users getting to the MDs? Untrusted VLAN on a port, or are the APs doing Multicast aggregation?
    I assume wireless to wireless airgroup is working as expected?
    Chris Wickline | ACCA |
  • 4.  RE: Wired MDNS traffic
    MVP
    Posted Sep 20, 2021 08:19 AM
    Hi Chris,
    We're in Centralized mode.
    No, the MDs are not seeing any wired traffic even though we have the VLANS entered in on each MD. The VLANs are also tagged on the uplink port on the core.
    We're only using one port on each MD, a 10Gig SFP uplink that is trusted. We are not using multicast agg.  TAC told us that the only way this works is if the AP and the client are on the same VLAN.
    Wireless AirGroup is working perfectly.
    Thanks for the assistance.
  • 5.  RE: Wired MDNS traffic
    Posted Sep 20, 2021 08:57 AM
    So, if you are tagging the wired VLANs, the VLANs will need to be untrusted, so that way those users enter the user table.
    The other option, is to use AP Multicast aggregation which (I think?) is the recommended option. Essentially, you have APs sit in the same subnet as the wired users, and they forward the mDNS traffic to the controllers over a GRE tunnel. That way you don't need all your wired/wireless VLANs on the controllers, just the wireless ones.
    Multicast aggregation is what we use (2 7240 ~6K Wireless users, ~1K wired users) and it works really well.
    This is something TAC should definitely be aware of and able to help with. I'd either ask for another engineer or for escalation.
  • 6.  RE: Wired MDNS traffic
    MVP
    Posted Sep 20, 2021 10:06 AM
    I don't think we can use AP mulitcast agg. because our APs are on a different VLAN than our wired users.
    Dumb question but how can we include the VLANs on each controller but make them untrusted? Right now, we have a single 10gig uplink back to our core for each MD.
    Nathan Kuhl
  • 7.  RE: Wired MDNS traffic
    Posted Sep 20, 2021 11:18 AM
    You can also trunk the VLANs to the AP(s), and do it that way. The first link talks about doing that, the second link shows making trusted and untrusted
    mDNS AP VLAN Aggregation
    Configuring Trusted/Untrusted Ports and VLANs
    (As a side note, I would highly recommend using a unused port when running the untrusted/trusted commands, just to make sure it is doing what you want it to do. We originally did our wired airgroup this way, and it caused us issues, which is why we went with Aggregation route. YMMV)
  • 8.  RE: Wired MDNS traffic
    MVP
    Posted Sep 20, 2021 08:46 PM
    Thanks. I'll look into both scenarios.
    is the untrusted VLAN scenario new as of OS8? We didn't have to do this in OS6.
    Nathan Kuhl
  • 9.  RE: Wired MDNS traffic
    MVP
    Posted Sep 24, 2021 01:26 PM
    Just an update on this. TAC escalated me to the next tier. This tech support agent deals mostly with AirGroup. He's unable to determine why we're not seeing any mDNS traffic from wired clients. He said that trusted ports should still be forwarding traffic from wired clients and that making it untrusted is not necessary. We never had untrusted ports before on our controllers running AOS 6.5 in the past so that would seem to be true.
    We're currently running AOS 8.7.1.4. He believes that there could be a bug in this version and advised us to upgrade to 8.7.1.5. I'll update this thread with the results when we can do this.
    BTW, we're only on 8.7 because we plan on installing an AP-575 outdoors shortly. Otherwise, we'd be on the most stable version of 8.6.
    Nathan Kuhl
  • 10.  RE: Wired MDNS traffic
    Posted Sep 24, 2021 02:10 PM
    I must have imagined the untrusted VLAN. Not sure where I got that.
    That being said, I trunked a trusted VLAN  to test and devices in that VLAN started showing up in our list of Airgroup servers, so what you are trying to do should work. We are on 8.7.1.4 as well.
    Just for sanity, do you have the VLANs enabled in the openflow profile? (MD: show openflow-profile)
    The trunked VLANs need to be added to that profile on the MDs for the MM to process them, since you are running in centralized mode.
    If not, I can share a sanitized version of our config and maybe that'll point something out that maybe you are missing.
  • 11.  RE: Wired MDNS traffic
    MVP
    Posted Sep 24, 2021 02:17 PM
    Openflow was something that TAC was looking at and felt like something was off here. If I run that command on the MM, I get this:
    (ArubaMM) [mynode] #show openflow-profile
    show openflow-profile is not supported on this model!
    (SEM-MD02) #show openflow-profile
    Openflow-profile "default"
    Parameter Value
    controller-ip masterip:6633
    State Enabled
    Openflow mode passive
    Openflow version v1.3
    Auxiliary State Disabled
    Auxiliary Channel Port 6633
    VLAN ID or range(s) of VLAN IDs 1-4094
    custom-cert-file none
    custom-key-file none
    ca-certificate-file none
    openflow tls Disabled
    custom cert Disabled
    (SEM-MD02) #
    Nathan Kuhl
  • 12.  RE: Wired MDNS traffic
    Posted Sep 24, 2021 02:37 PM
    If you run these commands on the MM,
    show openflow-controller
    show openflow-controller switches
    show openflow-controller flow-table app-name AirGroup (AirGroup is case sensitive)
    The first one should show ofc enabled
    the second one should show all your MDs as up, with 4 capabilities (Flow, Table, Port and Queue)
    The third one, at least for me, shows multiple sessions within.
    Just a forewarning, I'm just comparing what I have in these settings and what works for my environment. I'm not saying these are best practice/how it should be.
  • 13.  RE: Wired MDNS traffic
    MVP
    Posted Sep 24, 2021 02:42 PM
    Thanks. It looks like it all checks out on my end. We have a cluster but only one MD is up at the moment due to another issue:
    (ArubaMM) [mynode] #configure t
    Enter Configuration commands, one per line. End with CNTL/Z
    (ArubaMM) [mynode] (config) #show openflow-controller
    Openflow-controller
    Parameter Value
    ofc state Enabled
    ofc host-ageout-time 3600 sec
    ofc mode passive
    ofc certificate-file none
    ofc key-file none
    ofc ca-certificate-file none
    ofc tls Disabled
    ofc port 6633
    ofc topology-discovery Disabled
    ofc auxiliary-channel-port 6633
    (ArubaMM) [mynode] (config) #show openflow-controller switches
    Switches
    Dpid IP Version Status Auxiliary-Status/Id Capabilities Description
    00:00:00:1a:1e:07:6a:d0 10.0.0.111:44435 v1.3 Up Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. Aruba7210 ArubaOS, 8.7.1.4 SEM-MD02 TV0002322
    Total number of switches: 1
    (ArubaMM) [mynode] (config) #show openflow-controller flow-table app-name AirGroup
    Flow-table
    Dpid In Port Src Mac Dst Mac Ether Src IP Dst IP Proto Src Port Dst Port App Name Actions
    00:00:00:1a:1e:07:6a:d0 * * * 0x86dd * * 17 * 1900 AirGroup output=
    00:00:00:1a:1e:07:6a:d0 * * * 0x800 * * 17 * 5353 AirGroup output=controller
    00:00:00:1a:1e:07:6a:d0 * * * 0x86dd * * 17 * 5353 AirGroup output=
    00:00:00:1a:1e:07:6a:d0 * * * 0x800 10.0.0.111 222.173.190.239 17 60001 60001 AirGroup output=controller
    00:00:00:1a:1e:07:6a:d0 * * * 0x800 * * 17 * 1900 AirGroup output=controller
    Total number of flows: 5
    Nathan Kuhl
  • 14.  RE: Wired MDNS traffic
    MVP
    Posted Sep 24, 2021 02:32 PM
    Does OpenFlow need to be enabled on our HP core or edge switches? Never heard of it until Aruba OS8.
    Nathan Kuhl
  • 15.  RE: Wired MDNS traffic
    MVP
    Posted Oct 12, 2021 07:05 AM
    Just an update on this. Updating to AOS 8.7.1.5 resolved the issue.
    Nathan Kuhl
  • 16.  RE: Wired MDNS traffic
    Posted Oct 12, 2021 08:49 AM
    We have the same problem since upgrading to 8.7 (from 8.5, for 503H hardware support). It works OK for a little while after an upgrade/reboot (I don't know if it's the MCR or MD reboot that fixes it) then the Airgroup servers gradually start disappearing after a few days.
    I tried debugging it with TAC and we turned on AP multicast aggregation and promptly broke the network with a flood of traffic, I had to unplug both MDs then revert the config on the MCR and plug them back in, so take care before you enable it.
    I haven't had time to open a new case after my old one (just looked it was in June!) was closed since TAC wanted a packet capture mirror of the MD port and I couldn't get one for some reason.
    James Andrewartha
  • 17.  RE: Wired MDNS traffic
    MVP
    Posted Oct 12, 2021 09:48 AM
    Ugh, not what I wanted to hear. We're only on 8.7 because of ONE AP-577 that isn't even been installed yet. If this continues to be a problem, then I might just roll back to 8.6 at the expense of the AP-577 until they can fix this.
    The concerning thing is that I told TAC the upgrade to 8.7.1.5 appears to fix the issue but they don't seem to be concerned as to why wired MDNS traffic is showing up again. Is it a bug? No one knows and TAC doesn't seem to want to find out.
    Nathan K
  • 18.  RE: Wired MDNS traffic
    Posted Oct 12, 2021 10:17 AM
    I'd roll back to 8.6 if I were you. Last year I ordered an AP-375 so I could stay on 8.5 which was rock solid, but I couldn't justify buying 11ac hospitality APs this year. Also if you have AP-515s, roll back since I still see several crashes a day.
    James Andrewartha
  • 19.  RE: Wired MDNS traffic
    MVP
    Posted Oct 12, 2021 10:33 AM
    Agreed. That'll have to be something done over Thanksgiving break.
    We're still rocking AP-315s in classrooms and AP-303Hs in dorm rooms and they're all fine.
    Nathan Kuhl
  • 20.  RE: Wired MDNS traffic
    Posted Oct 13, 2021 11:25 AM
    A used AP-375 or AP-377 can be had on ebay for ~$500. It seems like a pretty cheap insurance policy to allow you to stay on 8.6 until there is an 8.7 conservative release. When the time comes that you can run the 57x on a CR, the 37x can retire to serve as a spare.
    Cathy Fasano
  • 21.  RE: Wired MDNS traffic
    MVP
    Posted Oct 15, 2021 06:43 AM
    Sure enough, after a few days, all wired MDNS dropped off. TAC suggested a roll back to 8.6 instead of trying to find the bug, which I find odd. I'll be doing this the next chance I get.
    Nathan Kuhl
  • 22.  RE: Wired MDNS traffic
    MVP
    Posted Nov 08, 2021 07:39 PM
    Well I downgraded to 8.6.0.15 and so far so good. All wired mDNS devices are able to be discovered by wireless clients. I'll keep this updated as the week goes on.
    Nathan Kuhl
  • 23.  RE: Wired MDNS traffic
    Posted Dec 01, 2021 03:04 PM
    We had to roll back to 8.7.1.5 due to an issue with our NAC. After a reboot of the controller, not the MM, wired AirGroup servers reappear. Then about 3 days to a week later, they drop off again until the next reboot.
    Just to be clear, when we look at AirGroup servers in the CLI, there are three kinds: wireless, wired, and N/A. The servers showing up as N/A are the problem. These are the devices connected to an edge switch, or the core, and not into an Aruba AP like a 303H. Those show up as wired and never drop off.
    Nathan Kuhl
  • 24.  RE: Wired MDNS traffic
    Posted Dec 14, 2021 06:46 AM
    Keeping this thread updated if anyone else runs into this issue. After a lot of troubleshooting, disabling/enabling Openflow brings all of the wired "N/A" servers back on the controller.
    This has to be a bug. I've re-opened the case with HPE to diagnose further.
    Nathan Kuhl
  • 25.  RE: Wired MDNS traffic
    Posted Dec 16, 2021 11:27 PM
    So at one point on 8.7.1.5 I rebooted one of our two 7205s and I think the vMCR, and after that the wired servers didn't disappear. I upgraded to 8.7.1.7 11 days ago which involved rebooting all three and am down to 12 of 90 now.
    James Andrewartha
  • 26.  RE: Wired MDNS traffic
    MVP
    Posted Dec 17, 2021 05:59 AM
    What do you mean you're down to 12 of 90 now? Do you mean only 12 of 90 wired severs are showing up?
    If so, try disabling Openflow on the MC or any of the MDs, then re-enable it. This fixes it for me temporarily.
  • 27.  RE: Wired MDNS traffic
    Posted Dec 19, 2021 11:08 PM
    Yeah, only 12 of 90 wired servers currently show from "show airgroup cppm entries". It's holidays here until February so I'll leave it broken until then since I might find time to work with TAC on it.
    James Andrewartha
  • 28.  RE: Wired MDNS traffic
    Posted Dec 20, 2021 08:32 AM
    Wow until February? Our break just started but we come back on the Jan 2.
    If you can keep this thread updated with your progress, should you contact TAC, then I'd appreciate it.
    Nathan Kuhl
  • 29.  RE: Wired MDNS traffic
    Posted Jan 23, 2022 09:52 AM
    Hey James,
    Check to make sure that your controllers are reading the AirGroup config from the main folder by running: show airgroup switches
    The jury isn't out yet but this might have been our main issue. Running the above command was showing that each switch was running its own AirGroup config. This is the fix:
      • - Disable AirGroup service
      • - Delete the existing profile
      • - Reboot the MM
      • - Create a new AirGroup profile from /md/Sem folder
      • - Make sure all the configuration for AirGroup are pushed from the upper hierarchy (show airgroup servers (from main folder))
    If you can report back either way, then I'd appreciate it. Thanks!
    Nathan K
  • 30.  RE: Wired MDNS traffic
    Posted Jan 24, 2022 04:02 AM
    I didn't have time to deal with TAC, so we're still broken, all wired servers are missing, just got the two wireless servers defined in ClearPass Guest. What's the command to disable openflow?
    Nope, the config is the same across all MDs:
    (lagrange-0) [CCGS] # show airgroup switches
    Showing AirGroup switches under /md/CCGS
    AirGroup Switch table
    Mac IP Node path Config path Active Profile Centralised/Distributed
    00:50:56:90:d8:0d 10.70.30.14 /md/CCGS/DMZ/00:50:56:90:d8:0d /md/CCGS aristarchus-airgroup-prof Centralised
    20:4c:03:58:29:d2 10.70.30.11 /md/CCGS/20:4c:03:58:29:d2 /md/CCGS aristarchus-airgroup-prof Centralised
    20:4c:03:58:26:2a 10.70.30.12 /md/CCGS/20:4c:03:58:26:2a /md/CCGS aristarchus-airgroup-prof Centralised
    Num Switches:3
    James Andrewartha
  • 31.  RE: Wired MDNS traffic
    Posted Jan 24, 2022 09:44 AM
    Hey James,
    I don't know the CLI command off the top of my head.
    In the web interface: [Main folder] -> Configuration -> System -> Profiles -> Controller Profile -> Openflow-profile -> [uncheck the State box]. Submit then apply the pending changes. Then check the box to re-enable Openflow and submit the changes.
    Let me know if disabling then re-enabling Openflow has any effect.
    Nathan K
  • 32.  RE: Wired MDNS traffic
    Posted Jan 24, 2022 12:19 PM
    Yep, about 80 came back within half a minute of re-enabling openflow. Still missing 10 but they might show up later
  • 33.  RE: Wired MDNS traffic
    Posted Jan 24, 2022 12:33 PM
    Coincidentally, all of my wired printers dropped off this morning after staying available for over 2 weeks. There must be a bug in 8.7, whether it's in regards to open flow or not.
    Nathan K
  • 34.  RE: Wired MDNS traffic
    Posted Jan 25, 2022 08:13 AM
    Once wired servers begin to drop off, I've confirmed the workaround is to disable/re-enable Openflow at the folder level. Then, if you rely on AirPrint for iOS devices, those printers will need to be rebooted before iOS devices will discover them. I use the HP WebJet Admin utility to reboot all of our HP AirPrint printers.
    I'll try and open another case with TAC. I just have to find a few hours to do troubleshooting with them.
    Nathan K
  • 35.  RE: Wired MDNS traffic
    Posted Feb 02, 2022 08:03 PM
    Our wired Airgroup servers continue to drop off on 8.7 since September 2021. At best the wired server remain visible for up to two weeks. I had two TAC engineers look at it multiple times. Sadly this problem has continued to plague us without resolution. I would like to know if downgrading to 8.6 is a possible solution?
    We have two 7210s in a cluster with two virtual Mobility Conductor setup by Victor F. exactly 1 year ago who knows what he is doing.  Updating to 8.7 was when we first noticed the wired server failure.
    I turned of Airgroup since our devices are wired and it causes confusion to all the users when the device list changes. Thankfully Apple TV devices are visible with bluetooth for Mac devices which make up most of our fleet. Right now PC users are without a solution. Please keep this thread open until a solution is found.
    William Galway
  • 36.  RE: Wired MDNS traffic
    Posted Feb 02, 2022 08:14 PM
    I was just on another support call with TAC this afternoon about this issue. They don't have a clue at this point. They've asked me to tech-support logs in working condition, re-collect as the servers start to drop off, then collect again after Openflow has been disabled/enabled.
    The only workaround at this point is to disable Openflow, submit the changes, then re-enable it and submit the changes. This instantly brings all wired servers back.
    I don't know enough about Openflow to point fingers but there is a bug somewhere in 8.7. I'm just glad that others are confirming it as I thought there was something wrong with my config.
    Nathan K
  • 37.  RE: Wired MDNS traffic
    Posted Feb 03, 2022 08:52 AM
    About an incorrect configuration . I performed a diff comparison of our config prior to 8.7 and our changes were simply WLAN changes to SSID passphrases while adding an additional Virtual AP profile. We ran 8.6 for about 7 months without a wired server issue.
    William Galway
  • 38.  RE: Wired MDNS traffic
    Posted Feb 03, 2022 09:11 AM
    I'm thinking it's an AirGroup bug at this point. And the only reason that it hasn't been found out yet is that most are still on 8.6. But time will tell.
    Nathan K
  • 39.  RE: Wired MDNS traffic
    Posted May 26, 2022 08:44 PM
    Well, it happened again, randomly, and after 5 weeks and 3 days instead of the normal 3 days or 2 weeks. I forgot to grab the logs before restarting Openflow at the folder level. It makes it almost impossible to troubleshoot.
    BTW, we're currently running 8.7.1.9 and I still think it's a bug until I'm proven otherwise.
    Nathan K
