Wired Intelligent Edge
Wired NAC - Critical Authentication
  • 1.  Wired NAC - Critical Authentication
    Posted Jun 30, 2020 10:16 AM
    I am replacing Cisco switches with Aruba 2930M (AOS 16.10.7) for one customer and I have two questions about critical authetnication:
    1- If I use user-role (local roles and not downloadable) as in this command:
    # aaa authorization user-role enable
    Can I use data-vlan and voice-vlan for critical authentication as in these commands below?
    # aaa port-access 3 critical-auth data-vlan X
    # aaa port-access 3 critical-auth voice-vlan Y
    Is it a must to use local user-role for critical authentication?
    2- In critical authentication using data-vlan and voice-vlan, there is no way to leave VLAN-ID empty so switch use the same configured data and voice vlans for critical authentication. In Cisco switches, I can enable critical authentication and leave VLAN-ID empty so the port will get the current data and voice VLANs if radius server is not reachable. The configuration is as below in Cisco:
    #authentication event server dead action authorize
    #authentication event server alive action reinitialize
    #authentication event server dead action authorize voice
     Is there any thing equivalent in Aruba?
