Hi All,
We have witnessed numerous AP-635 and Polycom phone reboots that we suspect are caused by LLDP port access role failures/mismatches/disconnects. We believe this because the show LLDP neighbor-info port indicates the following for related interfaces:
Neighbor Entries Deleted : 84
Neighbor Entries Dropped : 0
Neighbor Entries Aged-Out : 84
Access: 6300M Versions 10.13.1010 and 1040 (on some test stacks with no difference in issue)
Core: 8325-48Y8C Version 10.13.1040
I have already opened a TAC case but we are about to begin the fall semester and do not want phones rebooting in the middle of important conversations. We can put a bandaid on it by statically configuring the VLAN, but prefer not to take that step back before exhausting all other options.
LLDP Global Configuration
LLDP Enabled : Yes
LLDP Transmit Interval : 30
LLDP Hold Time Multiplier : 4
LLDP Transmit Delay Interval : 2
LLDP Reinit Time Interval : 2
LLDP Trap Enabled : No
TLVs Advertised
Management Address
Port Description
Port VLAN-ID
System Capabilities
System Description
System Name
OUI
Port VLAN-Name
Dot1 Link Aggregation
LLDP Port Configuration
PORT TX-ENABLED RX-ENABLED INTF-TRAP-ENABLED
1/1/1-1/1/48 Yes Yes Yes
Port-Access config:
port-access lldp-group aruba-ap
seq 10 match sys-desc ArubaOS
port-access lldp-group poly
seq 10 match sys-desc Poly
port-access role ArubaAP
client-inactivity timeout none
session-timeout 31536000
mtu 9198
poe-priority high
reauth-period 31536000
vlan access name AP-Interconnect
port-access role VoIP
poe-priority critical
trust-mode dscp
vlan trunk native 72
vlan trunk allowed 72,700
port-access device-profile ArubaAP
enable
associate role ArubaAP
associate lldp-group aruba-ap
port-access device-profile VoIP
enable
associate role VoIP
associate lldp-group poly
port-access auto-vlan
One of the problem phone interface config:
Hemmingson-0W# show running-config interface 2/1/42
interface 2/1/42
description JK:0WR1B42:Rm:010E:svc::
no shutdown
mtu 9198
apply policy VLAN0072-Policy in
apply policy VLAN0072-Policy out
no routing
vlan access 72
rate-limit unknown-unicast 1024 kbps
rate-limit broadcast 1024 kbps
rate-limit multicast 25000 kbps
rate-limit icmp ip-all 1024 kbps
client track ip enable
client track ip update-interval 300
apply fault-monitor profile port-faults
loop-protect
loop-protect vlan 700
exit
Sometimes LLDP shows incomplete as if the interface had not recieved LLDP data:
Hemmingson-0W# show lldp neighbor-info 2/1/42
Port : 2/1/42
Neighbor Entries : 1
Neighbor System-Name :
Neighbor System-Description :
Neighbor Chassis-ID :
Neighbor Management-Address :
Chassis Capabilities Available :
Chassis Capabilities Enabled :
Neighbor Port-ID :
Neighbor Port-Desc :
Neighbor Port VLAN ID :
TTL :
Other times it shows correctly (show cmds run seconds apart with no interface change):
Port : 2/1/42
Neighbor System-Name : Polycom VVX 501
Neighbor System-Description : Polycom;VVX-VVX_501;3111-48500-001,1;SIP/6.4.6.2640/13-Dec-23 14:31;UP/6.4.6.2224/13-Dec-23 14:42;
Neighbor Chassis-ID : 10.192.11.255
Neighbor Management-Address : 10.192.11.255
Chassis Capabilities Available : Bridge, Telephone
Chassis Capabilities Enabled : Telephone
Neighbor Port-ID : 64:16:7f:3e:e4:cd
Neighbor Port-Desc : 1
Neighbor Port VLAN Name :
Neighbor Port MFS : 0
Link aggregation supported :
Link aggregation enabled :
Aggregation port ID :
TTL : 120
Neighbor PoE information : MED
Neighbor Power Type : PD
Neighbor Power Priority : Unknown
Neighbor Power Source : BOTH
PD Requested Power Value : 8.00 W
PSE Allocated Power Value : 8.00 W
PD Associated TLV : med
PD Requested TLV types : med
Neighbor MED Capabilities
Neighbor Device class : CLASS_III
MED capabilities enabled : Capabilities, Network Policy, PD, Inventory
MED capabilities supported : Capabilities, Network Policy, PD, Inventory
Neighbor Med Network Policy
Neighbor Med Application type : video-conference
Neighbor Med Policy VLAN ID : 700
Neighbor Med Policy Priority : 5
Neighbor Med Policy DSCP : 46
Neighbor Med Policy Unknown : false
Neighbor Med Policy Tagged : true
Neighbor Med Application type : voice
Neighbor Med Application type : voice-signaling
Neighbor Med Policy DSCP : 24
Neighbor Mac-Phy details
Neighbor Auto-neg Supported : true
Neighbor Auto-Neg Enabled : true
Neighbor Auto-Neg Advertised : 1000 BASE_TFD, 100 BASE_TXFD, 100 BASE_TX, 10 BASET_FD, 10 BASE_T
Neighbor MAU type : 1000 BASETFD
Neighbor EEE information : DOT3
Neighbor TX Wake time : 0 us
Neighbor RX Wake time : 0 us
Neighbor Fallback time : 0 us
Neighbor TX Echo time : 0 us
Neighbor RX Echo time : 0 us
Not sure if there is something misconfigured or a bug.
Here is a log sample corresponding to a link state change and phone reboot:
Interface 2/1/42 is up
Admin state is up
Link state: up for 11 minutes (since Wed Aug 21 10:22:50 PDT 2024)
Yes, the cable is good:
Cable Impedance Distance* MDI
Interface Pinout Status (Ohms) (Meters) Mode
2/1/42 1-2 good 85-115 -- mdi
(5G-SmartRate) 3-6 good 85-115 -- mdi
4-5 good 85-115 -- mdi
7-8 good 85-115 -- mdi
Hemmingson-0W# show events -r | include 2/1/42
2024-08-21T10:24:24.100917-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:24:12.253337-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 172.24.135.72 added on 2/1/42
2024-08-21T10:24:09.252417-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 172.24.135.72 added on 2/1/42
2024-08-21T10:24:08.388552-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:24:08.313911-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 0.0.0.0 added on 2/1/42
2024-08-21T10:24:08.311604-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 172.24.135.72 added on 2/1/42
2024-08-21T10:24:08.309482-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:24:06.272654-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:23:53.864046-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:23:53.810234-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 0.0.0.0 added on 2/1/42
2024-08-21T10:23:53.810030-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 172.24.135.72 added on 2/1/42
2024-08-21T10:23:53.809795-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:23:52.901684-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:23:52.863431-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:23:52.815896-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 0.0.0.0 added on 2/1/42
2024-08-21T10:23:52.815650-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 172.24.135.72 added on 2/1/42
2024-08-21T10:23:52.814644-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:23:50.827810-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:23:25.176162-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 0.0.0.0 added on 2/1/42
2024-08-21T10:23:25.175484-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:23:14.871727-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:23:14.806755-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 0.0.0.0 added on 2/1/42
2024-08-21T10:23:14.804702-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 172.24.135.72 added on 2/1/42
2024-08-21T10:23:14.804418-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:23:12.776611-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:22:54.181418-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 0.0.0.0 added on 2/1/42
2024-08-21T10:22:51.158328-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 0.0.0.0 added on 2/1/42
2024-08-21T10:22:51.158084-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 172.24.135.72 added on 2/1/42
2024-08-21T10:22:50.301879-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:22:50.186832-07:00 Hemmingson-0W intfd[927]: Event|403|LOG_INFO|UKWN|1|Link status for interface 2/1/42 is up at 1 Gbps
2024-08-21T10:22:46.322534-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:22:46.193772-07:00 Hemmingson-0W intfd[927]: Event|404|LOG_INFO|UKWN|1|Link status for interface 2/1/42 is down
2024-08-21T10:22:35.180500-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 172.24.135.72 added on 2/1/42
2024-08-21T10:22:34.186358-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 172.24.135.72 added on 2/1/42
2024-08-21T10:22:32.155329-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:22:30.999380-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:22:30.101736-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:22:30.047491-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:22:29.996074-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:22:28.018258-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:22:17.805643-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:22:17.763895-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:22:17.307109-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:22:17.230520-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:22:17.177195-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:22:15.197907-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:22:07.040039-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:22:06.982037-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:22:04.953006-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:22:02.812199-07:00 Hemmingson-0W lldpd[3955]: Event|113|LOG_INFO|CDTR|1|PVID mismatch on 2/1/42 pvid = 72, Neighbor 10.192.11.255 port_id = 64:16:7f:3e:e4:cd pvid = 0
2024-08-21T10:22:02.786339-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:22:00.782828-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:22:00.739633-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:59.820228-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:59.783790-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:59.744243-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:57.745778-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:55.637505-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:55.597404-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:54.795575-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:53.641034-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:53.596916-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:52.699382-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:52.641964-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:52.602812-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:50.590680-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:47.847465-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:47.816525-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:47.770136-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:44.617197-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:44.571209-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:42.578536-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:41.218220-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:39.264636-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:39.217918-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:38.324495-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:38.270697-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:38.223559-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:36.227727-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:29.212037-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:29.156413-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:28.331606-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:28.207819-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:28.162294-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:26.167456-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:17.808751-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:17.766458-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:16.053777-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:14.051388-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:14.015143-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:13.762528-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:11.636195-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:09.027776-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:08.984081-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:06.047731-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:21:05.986256-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:21:04.074884-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from native-untagged to access on VLAN 72
2024-08-21T10:21:01.727781-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
2024-08-21T10:20:58.777960-07:00 Hemmingson-0W ops-switchd[1086]: Event|2107|LOG_INFO|CDTR|1|The mode for port 2/1/42 changed from access to native-untagged on VLAN 72
2024-08-21T10:20:58.731979-07:00 Hemmingson-0W lldpd[3955]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor 10.192.11.255 added on 2/1/42
Any thoughts or suggestions for config chganges are appreciated in advance!!!
Sean
