Wired ports not working for internet
  • 1.  Wired ports not working for internet
    Posted Jan 09, 2018 04:56 PM
    I have a RAP-3wn running latest firmware. It will connect to my router via wifi and will broadcast wifi and allow clients to connect with internet no issues. But the wired connection will not enable connection to the internet, UNLESS, I go to the wired setting and do Next, Next, Next... Then I disable and enable the desktops eth adaptor and walla, I get an IP and am good. I make 0 changes to any of the settings, just walk through the screens and it works!?
     Under my wired config, I have a default_wired_portProfile assigned to 0/0 with Primay usage as Empoyee. POE is disabled, Admin status is up. Uplink is disabled spanning tree is enabled.
    Vlan: Mode Access Client IP: Virtal Controller... Security: all disabled  Access all Urestricted.
    Any ideas how to get it to work by default?
    I tried setting 0/2 to the default wired port profile with no changes.
    Port 0/1 is wired-instant and can get to the management console no problem.
