Wireless Access Options
  • 1.  Wireless Access Options
    Posted Apr 04, 2018 10:30 AM
    Hello All,
    I'm researching the best approach to configure wireless access to a "private" lab. The private lab is only on a single floor of a single building and only on a single switch stack. I trying to give them wirless access to there private lab with our existing wireless infrastructure. I know there are different options to acheive this such as Instant AP and different forwarding modes. If I didnt want to go the Instant AP route, which foward mode would be the best way to acheive this goal (Bridge / Split Tunnel).
    I'm looking to create a new SSID and have just the one of the muliple SSIDs local switched to the switch port the AP is connected. I have attached a diagram to illustrate my goal. In the example below, SSID Public is tunneled back to WLC while SSID Private is local switch / offloaded /Bridged to the switch. Bridge_Approach.png
    Would the best appraoch be bridge mode? From my readings, the bridge scenerio is from a single SSID that has "corp" traffic going back to the WLC and local traffic being bridged.  My in case, I want a single SSID to be "bridged" while other SSID remain tunneled.
    Sorry for the inter change in terms as I'm new to the aruba world.
    Thanks!
    Kanan
  • 2.  RE: Wireless Access Options
    Posted Apr 04, 2018 12:11 PM
    Bridge mode is typically not recommended, but in this case may be your best option. It should be possible as long as you have CPSec currently enabled on your controller/APs.
    Depending on the switch make/model, you possibly could also tunnel the lab VLAN to the WLC so that it can place users directly in that VLAN. Tagging the VLAN and building a connection from the WLC to that VLAN on the lab switch would be the most preferred option.
  • 3.  RE: Wireless Access Options
    Posted Apr 04, 2018 02:33 PM
    Thank you for the response. These are not the aruba switches so we are not able to take advantage of that feature :(.
    Thank you!
