Wireless AP CPU and Memory Triggers and Reports
  • 1.  Wireless AP CPU and Memory Triggers and Reports
    Posted Apr 04, 2013 10:15 AM
    I've been trying to use the memory and CPU utilization triggers and report for wireless access points.  It works great for the controller but doesn't seem to work for the APs.  AP - Procurve MSM422, Contoller - MSM760.  Is there a compatiblility issue?
  • 2.  RE: Wireless AP CPU and Memory Triggers and Reports
    Posted Apr 04, 2013 06:10 PM
    Will try to get someone to replicate this with some devices in our lab.  Some devices do not provide CPU / Memory data for AMP to trigger against.  Will update with more info after testing.
  • 3.  RE: Wireless AP CPU and Memory Triggers and Reports
    Posted Apr 05, 2013 06:32 PM
    Memory and CPU Utilization reports and triggers can be generated only in the controller level.
    We do have AP options in them but that is for FAT AP's and some iOS devices.
    Jeyashree
  • 4.  RE: Wireless AP CPU and Memory Triggers and Reports
    Posted Apr 05, 2013 06:46 PM
    Are you saying that if the AP was in standalone mode, Airwave would be able to do CPU and memory triggers?
  • 5.  RE: Wireless AP CPU and Memory Triggers and Reports
    Posted Apr 05, 2013 07:11 PM
    Yes exactly. We dont get these statistics from thin ap's and so we cannot generate alerts or reports.
    Thansk,
    Jeyashree
